YOUR current LSJ setup
zzp 4340 rods
9.5-1cr df pistons
zzp Turbo swapped
s256et
zzp nbs
zzp 82# valve springs
brfps
stealth fp
80# injectors
zzp s2 turbo cams
zzp s4 clutch
zzp s3 axles
70/30 meth
p&p head
3.25" custom exhaust
n2mb 2step/wot box
stance GR+ coils
zzp motor and trans mounts
cf hood&trunk
wideband, interceptor, oil pressure gauges
I think that's about it =) oh and I forgot my wingless mod lol
9.5-1cr df pistons
zzp Turbo swapped
s256et
zzp nbs
brfps
stealth fp
80# injectors
zzp s2 turbo cams
zzp s4 clutch
zzp s3 axles
70/30 meth
p&p head
n2mb 2step/wot box
stance GR+ coils
cf hood&trunk
[QUOTE=05ssLSJT;6812247]zzp 4340 rods
9.5-1cr df pistons
zzp Turbo swapped
s256et
zzp nbs
brfps
stealth fp
80# injectors
zzp s2 turbo cams
zzp s4 clutch
zzp s3 axles
70/30 meth
p&p head
n2mb 2step/wot box
stance GR+ coils
cf hood&trunk
I think that's about it =) oh and I forgot my wingless mod lol[/QUOTE
Damn son got any dyno #'s?
9.5-1cr df pistons
zzp Turbo swapped
s256et
zzp nbs
brfps
stealth fp
80# injectors
zzp s2 turbo cams
zzp s4 clutch
zzp s3 axles
70/30 meth
p&p head
n2mb 2step/wot box
stance GR+ coils
cf hood&trunk
harrop tvs 2.7
E-85
80#
Injen CAI
ZZP long tube catless 3" with lnf flange
custom 3" catback magnaflow resonator and a stainless works muffer/tip
CX Racing H/E
Euthanasia custom flow-thru tank
dual pass
deatschwerks DW300
ottp return style
fuel pump rewire
phenolic intake gasket
aeroforce gauge
autometer phantom II boost gauge
AEM uego
tc shocks and struts/pedders
OTTP trans mounts
stage 1 axles
gmpp cluch kit
06blackg85ss bcp tuned
335hp 282tq
winter project
pnp head
82# valve spring
zzp stage 2 cams
nbs
ati balancer
id 1000's
yyz springs
powell rear sway bar
zzp stealth h/e
E-85
80#
Injen CAI
CX Racing H/E
dual pass
deatschwerks DW300
ottp return style
fuel pump rewire
aeroforce gauge
AEM uego
OTTP trans mounts
stage 1 axles
gmpp cluch kit
335hp 282tq
winter project
pnp head
82# valve spring
zzp stage 2 cams
nbs
ati balancer
id 1000's
yyz springs
zzp stealth h/e
Damn son got any dyno #'s?[/QUOTE] 432whp 397wtq @25.5psi sorry no dyno sheets lol. was trying to crank boost up a little but tuner wouldn't let me and started to have traction issues on dyno. he is begging me to switch to e85 but I don't wanna! haha
Big shout out John, thanks!
Yeah ill post some graphs tomorrow. We are trying to figure out a fuel pressure bobble under max boost. It has another 15 whp in it at least
I posted a summarized mod list in my FP issue at wot thread
Car is still strapped to the dyno at 21st century musclecars in Dallas
My buddy matt is their tuner
ZZP Girdled Block, 9.5:1 diamond pistons, pauter rods. ARP head studs, Billabong ported head. STOCK BALANCE SHAFTS, ZZP stage 2 cams, 82# valvesprings
Harrop w/ 2.7" pulley, ATI OD Crank damper
Return style with fuel lab regulator, deatvhwerks DW300 pump, 80# injectors, pump rewire, E85
372 whp/ 290wtq at 7250 rpm. Sad she wont rev beyond it without going lean
My Current LSJ Setup
Here is my Current LSJ Setup
No Dyno Data on Current Setup
Current Setup my 1/4 mile = 14.5 @ 100 MPH
Yes I know I should be faster
WHP = 240 On Dynojet at Dothan's Race Shop With ZZP Stage III Canned Tune and 2.85" Pulley and Spec Stage ?unknown? Clutch
WHP = 269 On Mustang at ZZP's Shop With ZZP Stage III Canned Tune and 2.85" Pulley
WHP = 271 On Mustang at ZZP's Shop With ZZP Stage III Custom Tune by Turbo Tim and 2.85" Pulley
Hey RiceBurner
Your setup is similar to mine.
Who did your tune? Tim tolld me that running a 2.85" was abit too agressive and giving me KR at the top end and recomended me go 2.9". Do you have KR at the top end?
- Simmens 60# Injectors with Harness
- NGK 1 Step Cooler Plugs
- ZZP 2.9" Pulley
- ZZP 3" Intake
- ZZP Long Tube Header w/ Catted Downpipe to Stock Exhuast
- OTTP Stg 1 H/E
- Dual Pass Intake Endplate
- LSJ Pheonalic Intake Spacer
- ZZP Stage III Custom Tune by Turbo Tim
- GMPP Clutch
- Upgraded Timing Chain Tensioner
Hey RiceBurner
Under the hood: (currently)
2.8” Pulley, Multiple Pulley System
60# Injectors
Injen Intake
ZZP Longtube Header/Catted Downpipe Combo
Ottp Stage 1 Heat exchanger
GM Stage 2 Belt
574's Dual Pass Endplate
ZZP Phelonic Manifold Spacer
NGK 1 Step Colder Spark Plugs
HPTuned
GMPP Clutch Upgrade Kit
60# Injectors
Injen Intake
GM Stage 2 Belt
HPTuned
Currently:
Engine:
- Eaton H62 Prototype "High Helix" Supercharger
- GMR Stage 3 PCM
- GMR Stage 3 76mm (2.992") Pulley
- GMPP (Siemens Deka) 42 lb/hr Injectors (48.29 lb/hr @ 3.8 Bar)
- GMPP Stage 2 Belt
- Production Donaldson Intake w/ Modified Airbox & K&N E-0777
- Ported/Polished Throttle Body
- 7,250 rpm Rev Limiter (7,000 rpm Shift Point)
Exhaust:
- Ported GMPP Extrude Honed Manifold
- Mufexpress 2.5" Downpipe w/ High flow Ceramic Cat
- Corsa Touring 2.5" Catback
Ignition:
- NGK/AC Delco (IFR6V-10G) Laser Iridium Plugs gapped @ 0.032"
Cooling:
- GMR Dual Pass Endplate
- GMR Option B Kit
- OTTP (4th Gen) Front Mount Heat Exchanger
Traction:
- Powell (Stage 1) Rotated Trans Mount
- GMPP Rear Trans Mount
Suspension:
- Moog (K750012) Sway Bar End Links
- Eibach Pro-Kit Springs
Braking:
- Powerslot Rotors
- Hawk Ceramic Pads
Over the winter:
- COMP Cams/ZZP S1 cams (ordered waiting to be shipped)
- Supertech 75 lb dual coil valve springs (currently sitting in my garage)
- 7500 rpm limiter
- Powell CABs or Hardcore Bar
Engine:
- GMR Stage 3 PCM
- GMPP Stage 2 Belt
Exhaust:
Ignition:
Cooling:
- GMR Option B Kit
Traction:
Suspension:
Braking:
- Powerslot Rotors
- Hawk Ceramic Pads
Over the winter:
- 7500 rpm limiter
