YOUR current LSJ setup
Old Nov 29, 2012 | 05:31 PM
  #226
574's Avatar
574
Originally Posted by ThexGovenor
How in the hell is that one dude running E85 on 60# injectors
Haha I don't know but I think Tjolley is also
Old Nov 29, 2012 | 05:34 PM
  #227
Area47's Avatar
Rent me! per hour
and about 3500lbs.....
cobalt. 3k lbs.
my truck is a 1/2 and under 5k lbs
Originally Posted by bratboy90
I missed that lol. Even so buddies turbo diesel that at like 450/550 can't beat a Stage 3 bolted-on G5....
im pretty sure i can.
Old Nov 29, 2012 | 05:37 PM
  #228
jrmotosports 88's Avatar
wasnt a 100% sure so i took a guess..... hahahaah
Old Nov 29, 2012 | 05:38 PM
  #229
ThexGovenor's Avatar
Engine explosion!
Old Nov 30, 2012 | 12:11 PM
  #230
JapEatr's Avatar
South Central *********
Old Nov 30, 2012 | 12:23 PM
  #231
Area47's Avatar
Rent me! per hour
shut off the ltft's.
retune the maf with stft.
above 15 msec you're pushing the injectors.
don't flat line the timing up top.
change the pump and add bigger injectors and aim for 11.0-11.3 afr at wot
Old Nov 30, 2012 | 12:56 PM
  #232
Texas SS's Avatar
Originally Posted by 06blackg85ss
current daily driver setup:
79lb racetronix injectors
E85
2.7 pulley m62
vibrant long tube header stock catback
airbox mod.
sitting @300whp at the moment, fun for daily driver, but miss my 500+whp setup I used to run, ah the good ol days
How are your intake temps on that 2.7? I cant decide between 2.7 2.8 for.meth
Old Nov 30, 2012 | 03:57 PM
  #233
rcorona8's Avatar
ported m62
ported head
supertech valves kit
meth
2.7 pulley
2.5 exh
zzp stage 2 cams
8k redline
Old Nov 30, 2012 | 09:20 PM
  #234
JapEatr's Avatar
Do you mean shut them off permanently? Still trying to figure out my over/under idle tables, still hunts and trys to die at stop light
Old Nov 30, 2012 | 09:45 PM
  #235
574's Avatar
574
Originally Posted by rcorona8
ported m62
ported head
meth
2.7 pulley
2.5 exh
zzp stage 2 cams
8k redline
very nice
Old Nov 30, 2012 | 10:58 PM
  #236
Area47's Avatar
Rent me! per hour
your car an 05 or 6?
Old Nov 30, 2012 | 11:24 PM
  #237
JapEatr's Avatar
Also what would cause it to randomly rev to 3k by itself when ata stop light?
I have done some over/under table adjustment and idle recovery after slowing to a stop light is much better. But every so often it revs by itself??
Bryan appreciate your input!
Old Nov 30, 2012 | 11:46 PM
  #238
RooTBeeR's Avatar
k&n cone filter in full stock intake
dual pass endplate
option b kit
2-bolt 3" exit on stock downpipe
3"x30" cherry bomb resonator
Tq managment removed
7500rpm limit
Made 215whp and 187wtq with just a RAW cai years ago.
Old Dec 1, 2012 | 12:12 AM
  #239
CobaltSS89's Avatar
60# inj
2.8
Cai
Tb spacer
E85
Stg 3 zzp h/e
Megan racing catback
3" zzp catless dp
That's it so far future plans are
P&p supercharger
2.7
Dual pass
Option b
Ls4 tb
3" zzp intake
Meth
Old Dec 1, 2012 | 05:33 PM
  #240
get 80's!
Old Dec 1, 2012 | 07:03 PM
  #241
CobaltSS89's Avatar
Who me? What exactly will the 80s do different then the 60s?
Old Dec 1, 2012 | 07:09 PM
  #242
Pleass's Avatar
What are yoi idc's wity 2.8 with 60s?
Has to be up there
Old Dec 1, 2012 | 07:53 PM
  #243
mrbelvedere's Avatar
its up there like a pornstar DAWG
Old Dec 1, 2012 | 08:04 PM
  #244
CobaltSS89's Avatar
Old Dec 1, 2012 | 10:02 PM
  #245
I thought 60's wouldnt keep up with a 2.8 pulley if you were on E85. Just get the 80's for insurance.
Old Dec 1, 2012 | 10:10 PM
  #246
Tjolley's Avatar
Im on 2.8 60s and e85 with out a problem
Old Dec 1, 2012 | 10:17 PM
  #247
Pleass's Avatar
Im curious on the idc on that
Old Dec 2, 2012 | 09:57 AM
  #248
CobaltSS89's Avatar
Yeah i that's what's i have and everything runs fine for me as well. But i have seen where others only run 80s with there e85 set up. Now if i do drop to the 2.7 then yea I'll probably get em then
Old Dec 2, 2012 | 06:23 PM
  #249
ULWizSS's Avatar
Here is mine:
06 SS/SC G85 LSD Turbo Swapped
BorgWarner EFR 6758 Turbo
BYT HP Tuned
BYT 304SS Tubular Manifold w/ Merge Collector
BYT 304SS Catless Down Pipe
BYT 3' CAI
BYT "Stealth" Charge Pipes
TTR Intake Manifold
TTR Upper Engine Mount
TTR Rear Sway Bar
ZZPerformance 2.1 Forged Shortblock
ZZPerformance Front/Rear Transmission Mounts
ZZPerformance Front Strut Bar
ZZPerformance Stage 2 Race Trans 4.45 Now a 6 Speed
ZZPerformance Stage 3 Axles
ZZPerformance Stage 2 Port and Polished Head
ZZP Stage 2 Comp Cams.
ZZPerformance Triple Gauge Pod
ZZPerformance Boost Reference Fuel Pressure System Option 2
VP Racing M1 Meth 50/50 Mix
Aeromotive Stealth Fuel Pump
Mototron 80# Injectors
Hallman Pro RX Manual Boost Controller
Eibach Front Sway Bar
Exedy Stage 3 Hypersingle Clutch (2nd one)
DevilsOwn Progressive Meth Kit
N2MB Wotbox NLS/2Step
AEM Uego/Boost/EGT
Aeroforce Intercepter Scan Gauge
Modern Performance MPx Steering Column Gauge Pod
Hurst STS
HP Tuners Software
15's Verde Protocols Rims
15's M & H Slicks (Track)
18's Falken Azenis RT-615k(Street)
Pioneer AppRadio
Kicker 1000Watt Amp
Dual 12's Kicker L3 Box
Excaliber Remote Start/Alarm
At ZZP right now for some changes again. Should be a little over 500 when all done.
Old Dec 3, 2012 | 01:39 AM
  #250
EXsoccer1921's Avatar
hows everything coming along there. i know its been a while
