Your opinion on some common mods
e85 will require bigger injectors because its has a higher duty cycle then pump gas, i would get 80s if I was u, I just bought some brand new 80s on here for 150 bucks so they is some good deals in the for sale section. 60s will run a pulley from 2.9 and up but if I was u id get the 80s and a 2.8 or 2.7 pulley from zzp. to run any injectors bigger then 42 u need a ecotect injector harness from zzp and make sure any injectors bigger then 42 are ev1 style injectors.
Crate Engine Depot
It's a very good read. Sadly, not many people follow it....
I'm in the process of getting my car close to the engine specs in Chapter 6 minus NB shafts and higher compression pistons.
This winter I'm installing Supertech 75 lb dual spring valve springs and cams
some people have had good and bad exp with trifecta id personally get hptune but id have trifecta do my tune before id go to a dyno shop thats never tuned an LSJ before.
I'll lead u in the right direction.
Just collect up the parts u need at one time and get ur turn done when u have everything installed
importkiller
Sep 30, 2015 07:18 PM
