ZZP Adjustable Tensioner question
Old Mar 13, 2013 | 05:57 PM
jpsgotboost's Avatar
Hey I have a quick question, my stage 2 belt on my 06 SS/SC broke so for the moment I put back on the stock one, and of course it squeals like a pig, but anyways I was wondering if I order the ZZP adjustable tensioner if I will still have to get another stage 2 belt or if it will take out the slack in the stock one enough to stop the squeal and work correctly?
Old Mar 14, 2013 | 12:38 AM
Vander Nars's Avatar
It depends on ur pulley i run a stage 2 belt n adjustible tensioner on a 2.7 pulley but im not using the tensioner set on its max setting so yeah the tensioner alone should be fine unless urs running a retarded small pulley like a 2.5.
Old Mar 14, 2013 | 02:22 PM
killtank's Avatar
Zzp makes so good products but I would not buy the adjustable tensioner. The adjustable tensioner is really difficult to depress. There is no way to depress the pulley unless you use a pry bar. I would stick with the stage 2 belt or stock belt with larger tensioner pulley. Hopefully someone from ZZP will chime in on the adjustable tensioner issue.
Old Mar 14, 2013 | 02:39 PM
Yes u can depress the tensioner iv done it serval times working on my car, its no harder then te stock style tensioner
Old Mar 14, 2013 | 04:00 PM
killtank's Avatar
How so vander? Mine doesnt have the uprise to grab onto with a wrench.
Old Mar 14, 2013 | 04:11 PM
killtank's Avatar
Can you use a t50 wrench?
Old Mar 14, 2013 | 04:32 PM
Yup thats what i use.
Old Mar 14, 2013 | 06:52 PM
killtank's Avatar
I never realized that till now lol. Oh man the trouble i could have avoided. I retract my previous post, its a awesome tensioner! Lol
Old Mar 14, 2013 | 08:02 PM
ok thanks, i have a 3.0" pulley for now so hopefully it will work. I believe my stock tensioner is going bad as it is making alot of noise so i plan to replace the entire thing with the zzp one, i have there stage 2 kit and there products seem to be very good quality.
Old Mar 14, 2013 | 11:08 PM
killtank's Avatar
You will need to reuse the stock pulley and bearing. If its noise its probably the bearing unless its a squeal like belt slip then its the tensioner shock (dont know correct name) itself.
Old Mar 14, 2013 | 11:10 PM
killtank's Avatar
Reading your original post it sounds like belt slip. Seeing your running a 3.0 you should use the first hole to the top on the tesnioner if you do get it.
Old Mar 15, 2013 | 02:18 PM
SaberD's Avatar
the boss on the stock tensioner is garbage. it is a rounded cast peice and a wrench just slips right off it. I weigh 170lbs, and I have to stand on the pulley with 1 foot and push against my garage ceiling to depress the stock tensioner. I'm eventually going with the ZZP tensioner without a doubt.
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
