ZZP Blower Spacer ?'s
Has anyone ever ran the ZZP blower spacer and the Phenolic IM spacer? Have you ran into any Clearence/belt/random issues running these together? I just recently installed the IM spacer, option b, and dual pass. Clearance is already somewhat tight with the IM spacer. Reason I'm wanting to run the blower spacer is because I'm going to run meth and id say it would be a cleaner install and better concealed running a meth line to the IM instead of the throttle body!
Thanks in advance!!!!
If clearance is tight without the spacer you will probably run into issues with the spacer in place. Plus, running meth through a throttle body spacer is going to be more effective for you. By injecting it there, you are cooling down the blower which is what is going to give you the most benefit. Injecting it after the blower will still give you the octane enhancing that meth does but will give you no cooling effect so you are limiting its capabilities.
Ahhhh, I'm glad you pointed that out. I hadn't even thought of cooling the blower itself. Thanks man, guess I'll stick with the TB spacer that is coming with the meth kit I'm getting!
