ZZP downpipe leaking!
I found where the noise is on mine it just doesn't sound like a leak it is one! The top bolt from the exhaust maniflod to the pipe has exhaust gas all over it and the gasket is falling apart(only on the top) So any with this downpipe might want to check! The downpipe was install by my dealer and check for leaks and then re-check by an exhaust shop a week later with no leaks. I will be going to ZZP for anwsers!
I just checked the bolt where the leak was and i got 1 and a 1/2 turns on the bolt and it doesn't seem to be leaking now, but i will have to replace the gasket when i got time
from what I've heard so far about the whistling sound, it's from the flex joint. It needs to build up some carbon first. Either that or spray it with high temp paint on the inside first.
Originally Posted by CobaltSS313
sorry i wasnt trying to be a smartass earlier but yah it seems to me that you found what was wrong with the downpipe and hopefully it will quit making the whistleing noise.
