ZZP downpipe leaking!
Old Jul 2, 2006 | 07:42 PM
Nuclear's Avatar
Angry ZZP downpipe leaking!
I found where the noise is on mine it just doesn't sound like a leak it is one! The top bolt from the exhaust maniflod to the pipe has exhaust gas all over it and the gasket is falling apart(only on the top) So any with this downpipe might want to check! The downpipe was install by my dealer and check for leaks and then re-check by an exhaust shop a week later with no leaks. I will be going to ZZP for anwsers!
Old Jul 2, 2006 | 09:17 PM
Toyotech's Avatar
sounds like a bad design. not the correct angle.
Old Jul 2, 2006 | 09:34 PM
Nuclear's Avatar
Or the flexible section is too stiff, i'm going to try and tighten it up tomorrow
Old Jul 2, 2006 | 09:37 PM
acceleratION's Avatar
our maybe that thin 5/8" flang is done already.
Old Jul 2, 2006 | 09:44 PM
BlackLS's Avatar
Do you mean 5/16" because 5/8" is really fing thick.
Old Jul 2, 2006 | 11:57 PM
05_Blue_B10WN_SS's Avatar
Hmm, I'll have to check mine out.. havent put it on the lift since the install.
Old Jul 3, 2006 | 12:19 AM
Brandon97Z's Avatar
I'll check mine tommorow.
Old Jul 3, 2006 | 02:28 AM
CobaltSS313's Avatar
yah something aint right there, let us know what you find out.
Old Jul 3, 2006 | 06:35 AM
yeah i ment 3/8"
Old Jul 3, 2006 | 10:55 AM
spooler's Avatar
i was going to get that downpipe to match my header. did you find anything out?
Old Jul 3, 2006 | 07:40 PM
Nuclear's Avatar
I just checked the bolt where the leak was and i got 1 and a 1/2 turns on the bolt and it doesn't seem to be leaking now, but i will have to replace the gasket when i got time
Old Jul 4, 2006 | 01:00 PM
dont you mean "doesnt seem to be leaking"?
Old Jul 4, 2006 | 07:13 PM
Nuclear's Avatar
thats right, i fixed the post
Old Jul 4, 2006 | 11:51 PM
sorry i wasnt trying to be a smartass earlier but yah it seems to me that you found what was wrong with the downpipe and hopefully it will quit making the whistleing noise.
Old Jul 5, 2006 | 01:15 AM
NGalaxyTimmyo's Avatar
from what I've heard so far about the whistling sound, it's from the flex joint. It needs to build up some carbon first. Either that or spray it with high temp paint on the inside first.
Old Jul 5, 2006 | 01:26 AM
sscobalt06's Avatar
sorry to get off topic here, but how is everyone liking the zzp downpipe? Is it worth the money, and what kind of gains are you getting?
Old Jul 5, 2006 | 08:43 PM
Nuclear's Avatar
No worries and the whistling noise is alot better now
Old Jul 5, 2006 | 10:02 PM
what do you mean by alot better, do you mean its louder or it went away, sorry ur post kinda confused me lol
Old Jul 5, 2006 | 10:49 PM
How did you end up fixing it?
Old Jul 8, 2006 | 09:05 PM
Nuclear's Avatar
I used muffler cement around the flange the noise is barly noticable now
biniecki
Oct 25, 2015 02:23 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
