ZZP Stage 2 cams. dyno proven difference.
Idk if you look at my sheet at 7500 the hp is still climbing at like a 40 degree angle.. How different is the custom grind you have from the stage 2 cams? And wow thats pretty impressive stuff from Area.
it may flat line soon after though my cams are a lot different then the zzp cams
one thing I think people are making a mistake on cam installation is your supposed to collapse the lash adjuster and set it to half extended
ZZPs dyno seems to read high for a mustang dyno. If you could you might want to get a second opinion on a dynojet if you can find one near you.
as a reference term, On my old E85 setup with a m62 2.8 pulley full exhaust and intake I made 267/247. thats why I kept using the same dyno so all the runs would be based on the same dyno. Ill be moving around for the next 6 months for the military but when I settle in ill try to get another dyno. You arent the first to say that ZZP's reads high. but idk I just wanted to stay on the same dyno so that it would be consistent.
And Mr B zzp installed my cams so Im pretty sure it was done right. why do you have to adjust the lashers?
Thats why I'm glad that there is a 2nd car show dyno day this year at the place I dyno'd in Minneapolis. Once I get my issues fixed I might as well run it again on the same dyno and see how much more then 370whp shes got in her.
