ZZP Stage 2 cams. dyno proven difference.
Old Jul 16, 2013 | 03:05 PM
  #51
ThexGovenor's Avatar
Idk if you look at my sheet at 7500 the hp is still climbing at like a 40 degree angle.. How different is the custom grind you have from the stage 2 cams? And wow thats pretty impressive stuff from Area.
Old Jul 16, 2013 | 03:08 PM
  #52
mrbelvedere's Avatar
it may flat line soon after though my cams are a lot different then the zzp cams
one thing I think people are making a mistake on cam installation is your supposed to collapse the lash adjuster and set it to half extended
Old Jul 16, 2013 | 03:12 PM
  #53
Terminator2's Avatar
ZZPs dyno seems to read high for a mustang dyno. If you could you might want to get a second opinion on a dynojet if you can find one near you.
Old Jul 16, 2013 | 03:16 PM
  #54
as a reference term, On my old E85 setup with a m62 2.8 pulley full exhaust and intake I made 267/247. thats why I kept using the same dyno so all the runs would be based on the same dyno. Ill be moving around for the next 6 months for the military but when I settle in ill try to get another dyno. You arent the first to say that ZZP's reads high. but idk I just wanted to stay on the same dyno so that it would be consistent.
And Mr B zzp installed my cams so Im pretty sure it was done right. why do you have to adjust the lashers?
Old Jul 16, 2013 | 03:44 PM
  #55
if the lash adj are at full extension upon installation they can hold the valves off seat a tad you release them and set them to mid stroke so they can adjust to the cam
Old Jul 16, 2013 | 03:53 PM
  #56
Staged07SS's Avatar
Administrator
Administrator
Good info^
Old Jul 16, 2013 | 03:58 PM
  #57
Ok I think I understand what you are saying. Good info.
Old Jul 16, 2013 | 04:00 PM
  #58
and no chassis dyno is 100% accurate they are tuning tools
Old Jul 16, 2013 | 04:03 PM
  #59
Definitely not just so many user inputs on a mustang dyno which can skew things and ZZPs seems to read much higher than any other mustang dyno out there I have seen.
Old Jul 16, 2013 | 04:08 PM
  #60
could be I was on their dyno when I broke block #2
Old Jul 16, 2013 | 04:19 PM
  #61
InfraRedline's Avatar
Thats why I'm glad that there is a 2nd car show dyno day this year at the place I dyno'd in Minneapolis. Once I get my issues fixed I might as well run it again on the same dyno and see how much more then 370whp shes got in her.
Old Jul 16, 2013 | 04:35 PM
  #62
do it to it mtdew
Old Jul 17, 2013 | 10:28 AM
  #63
If it reads high then im making a disappointing power level for my mods lol
Old Jul 17, 2013 | 10:33 AM
  #64
HEY YOU!!!!........Change your sig lol
Old Jul 17, 2013 | 10:41 AM
  #65
I changed it. A**hole
Old Jul 17, 2013 | 10:48 AM
  #66
Good, Goooooooood
Old Jul 17, 2013 | 11:47 AM
  #67
YelCal7's Avatar
Yes, Darth Sidious
Old Jul 17, 2013 | 02:20 PM
  #68
I wouldn't say that
Old Jul 17, 2013 | 02:43 PM
  #69
Im saying if the dyno reads high. If its accurate im happy.
Old Jul 17, 2013 | 02:59 PM
  #70
no dyno is accurate period take it to the track
Old Jul 17, 2013 | 03:04 PM
  #71
JapEatr's Avatar
South Central *********
I wouldn't say that
I wouldnt say that at all... You gained 30hp
Old Jul 17, 2013 | 03:37 PM
  #72
I would say it because he could have gained more or less it is a tuning tool nothing more people get to hung up on what it makes
Old Jul 17, 2013 | 07:58 PM
  #73
cavfiredesire's Avatar
How do you adjust the lash adjusters?
I have a set in front of me and dont see how.
Old Jul 17, 2013 | 08:58 PM
  #74
I gained 10 hp from the cams. it doesnt show the last pull all the way to 7500 where it made 348
Old Jul 17, 2013 | 11:11 PM
  #75
trying to figure that one out my self
