07blackg5 Build Thread. Operation Moneypit
Old Jun 10, 2015 | 02:42 PM
  #401
07blackg5's Avatar
Slobodan Milošević
m8x1.25 tap came today. Todays project is tapping the head out for the proper lsj intake manifold bolts
Old Jun 10, 2015 | 04:18 PM
  #402
Originally Posted by 07blackg5
Where we are going, we don't need A/C
And the compressor has been gutted for a year. I might end up just running the 2 bolt pulley piece
Just get the ac delete belt
Old Jun 10, 2015 | 04:19 PM
  #403
So now the question is does you car run first or Riceburners
Old Jun 10, 2015 | 04:41 PM
  #404
07blackg5's Avatar
Slobodan Milošević
There is no such thing for a blower ecotec.
I will speak for both of us and say that we dont want to talk about it
Old Jun 10, 2015 | 10:15 PM
  #405
Oh maybe im thinking of someone else who was building NA.
Yeah i have one on my turbo car
Old Jun 10, 2015 | 11:36 PM
  #406
07blackg5's Avatar
Slobodan Milošević
Yeah, the double sided belts are a gm only part. no other belt sizes available other than stock and stage 2. one sided belts you can get anywhere in 1/4" increment lengths lol
Old Jun 11, 2015 | 12:03 AM
  #407
07blackg5's Avatar
Slobodan Milošević
Finally got something done. More major than my other recent updates, but nothing crazy. Still something I've been putting off forever....
I paint penned the manifold holes so I wouldnt derp out and drill any extras. There are 2 other m6x1 holes on the drivers side of the head that I covered in tape. I then did a super professional job masking off the exposed areas. I set the valve cover on to keep shrapnel out as well. The head is going to be re-cleaned, but I still wanted to keep as much **** out as possible.
Shiny new m8x1.25 tap
First hole drilled out. The 17/64" bit was about the same as the OD of an m6 bolt, so it self alligned and basically just took the threads out. Easy as pie, but still nerve wracking lol.
I tapped the top center hole, and verified that it was proper/the depth was adequate before I went Jean-Claude Van Damme on the whole thing. After it checked out, I drilled out the rest of the holes.
Finishing up....
I cleaned off the paint pen, and test fit the manifold. If it fits, that bitch ships!
Overall it turned out pretty well, and went smoother than expected. You can tell that two of the bolts are ever-so-slightly off axis, and I was worried it would cause issues. When i test fit the manifold, everything threaded right in and sits flush. No issues whatsoever, which was relieving.
I also want to tap a boost reference port on the side of the manifold for the boost gauge and FPR somewhere in the area where I am pointing. Not sure how I am going to set it up yet, but I may run a small vacuum block, or maybe just a small 1/8npt Y fitting that isn't massive.
The FPR mounts directly to the side of the fuel rail, so you can see how it would make for a short and sweet vacuum line. This fuel rail needs cleaning up lol
And speaking of the fuel rail, I have to make some sort of bracket to support the hardline of the rail. Either off the furl rail mount bolt, or a valve cover bolt.
Old Jun 11, 2015 | 02:12 AM
  #408
Rsfs?
Old Jun 11, 2015 | 08:11 AM
  #409
07blackg5's Avatar
Slobodan Milošević
Yes. And id1000s
Old Jun 16, 2015 | 01:40 AM
  #410
07blackg5's Avatar
Slobodan Milošević
Got a few things accomplished today. Drilled out the nipple on the lsj manifold, and tapped it for a plug. I put a few marks on the manifold filing down the burred edges. haha its obviously never going to be seen, but I still felt bad since it is a minty manifold.
I also bolted up the fuel rail and FPR in order to check for clearances/where to run the new vacuum barb, and ran into a small, but aggravating issue. The 07-08 l61 cam sensor is in the direct path of the return line. Basically the most direct way to run the line is right through the cam sensor, which older l61 and lsj dont have in this location.
You can see here that if the line was attached, it would hit
If I got a new straight fitting, I could run the line down and around the sensor, but the line is not very flexible and requires a large radius. Not sure if this will work until I have the block/trans/fusebox in and know exactly where it will be run. Im sure I could get it to work like this, but my issue is the amount of stress put on the fpr/fuel rail from the tight radius in the line. I'm pretty confident this will workout fine, but I'm not sure how much extra "slack" there is in the line to work with. The difference between the 2 setups is minimal, but still potentially an issue. Worst case I just end up needing a longer section of hose. I am also deleting the EVAP canister from the rear of the car, so depending on how that works out I may have needed longer hose regardless. We will find out when that time comes
The other obvious option is to run a line between the rail and FPR, and mount the regulator somewhere else in the bay. It is my goal keep it on the rail, so this is a last resort. I spent a lot of time minimizing the amount of wires and lines in the bay, and it would kill me to add more than necessary. If i feel like the line is too stressed making the bend, and/or I cannot run the line safely/properly, I will just have to suck it up and remote mount it.
I also pulled the valve cover nipple from the crankcase to intake connection. I plan on plugging the hole, and venting to atmosphere through a oil cap breather. I was going to tap it tonight, but I dont have the correct size tap/plug.
Old Jun 16, 2015 | 08:33 AM
  #411
post
Old Jun 16, 2015 | 02:30 PM
  #412
07blackg5's Avatar
Slobodan Milošević
also forgot to mention I picked up some bigger cams, and the "revised" lifters
Old Jun 17, 2015 | 06:42 AM
  #413
Get a union or pipe nipple so you can mount the line like you have it in the first pic showing the issue. You'll have the 45* with the AN fitting not the line, then you can mount the line pretty close to where you planned initially.
Old Jun 24, 2015 | 11:28 PM
  #414
07blackg5's Avatar
Slobodan Milošević
Got my OTTP s4 cams, as well as my "revised lifters" in the mail this week. haha Boring picture:
I'm headed to OTTP tomorrow and needed to get the "downpipe" off of my car for Josh to modify, and pick up some misc parts. The stupid v-band was seized and gave me hell. had to torch and beat it with a flathead/hammer, but finally got it off. GBrunner has dibs on the catback, so i figured I would start pulling that as well.
It steps down to a 2.5 exit, so he is going to cut and weld in a 3" section and flange.
Just because I was finally able to get it out, and it is glorious haha:
While the car was up in the air, I drained the rest of the coolant, and used my dads Harley oil filter drip tray to keep from making a mess. Worked out perfectly
The tires looked meaty while I was under the car, but the picture doesnt give the same effect
It started getting dark, so I started pulling the last few remaining sensors than needed to come off. I just need to disconnect the heater core, shifter cables, clutch line, starter cables, and them Im ready to pull axles/ball joints/steering rack/swaybar/etc and drop the subframe. Progress has been slower than expected, but some things have come up. Still waiting on the shortblock, but inching along in the meantime.
Old Jun 25, 2015 | 09:10 AM
  #415
Keep it up
Old Jun 25, 2015 | 07:15 PM
  #416
07blackg5's Avatar
Slobodan Milošević
Just got back from ottp. Josh modified what needed modification, I picked up a few misc things, and got some questions answered. Always a pleasure working with him.
Hopefully this weekend I can get some serious work done
Old Aug 16, 2015 | 09:02 PM
  #417
GBRunner24's Avatar
The world needs updates....
Old Aug 16, 2015 | 10:12 PM
  #418
07blackg5's Avatar
Slobodan Milošević
Car was firebombed
Old Aug 16, 2015 | 10:22 PM
  #419
Car was firebombed
by owner?
Old Aug 17, 2015 | 03:57 AM
  #420
lolol
Old Aug 17, 2015 | 08:24 AM
  #421
O hay
Old Aug 31, 2015 | 03:05 PM
  #422
stenguyen1's Avatar
I didn't really read your entire build but just for reference, i have done a build like this already. i have provided links below. second link has a video of my car running with a tvs.
https://www.cobaltss.net/forums/2-2l...thread-238062/
https://www.cobaltss.net/forums/2-2l...ey-e85-279983/
Old Aug 31, 2015 | 04:01 PM
  #423
GBRunner24's Avatar
Dang, that had some nuts behind it!
Old Sep 3, 2015 | 07:32 AM
  #424
08_Slowbalt's Avatar
I love this build! However I have some questions about the previous build. What were you spraying before you started playing with the AFRs and what were you spraying when it blew lol. Hopefully I can avoid any issues because I do not have a spare block. I'd also like to know more about that WOT box and how much of a pain it was to wire into a cobalt. Also PM sent about the long tube header.
Old Sep 3, 2015 | 03:09 PM
  #425
Is it done yet
