2.2 stage 2 cams
defennitly a tune. valve springs and retainers would probably be fine unless you plan on revving higher.
and i belive you would also need to get a timing sensor put on because you have cam position sensors.
Ture, he would need to have the cam cut to a length, then have if it machined to fit the position sensor onto the end of the cam. Bates can do this. I would fill more safe if they threaded the senor onto the cam. Then lock it in place with an alen set screw of some sort.
