2.2 stage 2 cams
Old 11-25-2009, 10:17 AM
SpeedJunkies07LS's Avatar
2.2 stage 2 cams
i was wondering what all do i need for the stage 2 comp cam instal? like new valve spring an retainers, tune????? help?
Old 11-25-2009, 10:27 AM
ilovecars's Avatar
defennitly a tune. valve springs and retainers would probably be fine unless you plan on revving higher.
and i belive you would also need to get a timing sensor put on because you have cam position sensors.
Old 11-25-2009, 10:36 AM
MadBrad's Avatar
Ture, he would need to have the cam cut to a length, then have if it machined to fit the position sensor onto the end of the cam. Bates can do this. I would fill more safe if they threaded the senor onto the cam. Then lock it in place with an alen set screw of some sort.
Old 11-25-2009, 10:41 AM
copson20's Avatar
TUNE, 2.4 TB, 2.4 Manifold, Now i only know of one person that Bates pressed on the cam senor on to the cam. and his engine failed. But it think it was do to install failure.
05-28-2022 03:47 AM
HEATON
10-16-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
nathan112i
09-30-2015 07:12 PM
Dylan Johnson
09-30-2015 08:57 AM
Quick Reply: 2.2 stage 2 cams
