MAF swap?
Old Nov 22, 2009 | 08:10 PM
ilovecars's Avatar
MAF swap?
ok so i was thinking our maf sucks. this stupid rectangle bull **** dosent cut it for me.
so i was thinking would it be possible to swap in a say ls1 maf sensor? they flow much more fluid and you would be able to run a blow through turbo set up perfectly with this
do you guys think this is possible?
heres what im talking about
Old Nov 22, 2009 | 08:17 PM
outtamymind's Avatar
assuming you could get one in the right side, you pin the connector properly and you tune for it i can't see why not. anything is possible just depends on how far you want to take it.
Old Nov 22, 2009 | 08:24 PM
ilovecars's Avatar
yea repinnig as well as tune was a given but i dont know what voltage out maf runs off of.
Old Nov 23, 2009 | 03:26 PM
ilovecars's Avatar
Old Nov 23, 2009 | 03:28 PM
nhanson's Avatar
test with multimeter?
Old Nov 23, 2009 | 03:46 PM
ilovecars's Avatar
ehh. someone will chime in im pretty sure is a 0-5 volt maf what we use.
i have heard some people already swaped the ls4 tb in with almost no change in results? what gives?
Old Nov 24, 2009 | 01:36 AM
Jn2's Avatar
Jn2
ls4 tb doesn't make a diffrence on the lsj...it's being a potted and polished ls4 that makes the difference. And I'm sure Vince knows what the voltage is
Old Nov 24, 2009 | 04:07 AM
HunterKiller89's Avatar
just an FYI, you would be downgrading. You're talking about removing the MAF thats used in the LS7 and putting in the MAF thats used in the LS1?
most GM MAFs (including LSx MAFs and our MAFs) are frequency based, and not voltage based.
neither makes a difference. What makes a difference is when you're making 300whp and the stock TB becomes a restriction. Its a long ways down the list of restrictions though.
Last edited by HunterKiller89; Nov 24, 2009 at 04:07 AM. Reason: Automerged Doublepost
Old Nov 24, 2009 | 10:23 AM
blackbolt89's Avatar
iirc i thought having a bigger TB when it is not needed only created the air to be inducted at a slower velocity, therefore not making any significant difference.
i could be wrong.
Old Nov 25, 2009 | 12:45 AM
i could be wrong.
troof. Though, with the SC there, most of the piping pre-blower doesnt need to maintain velocity...just enough flow. So it wont hurt..but the stocker flows well enough that it wont help either
Old Nov 25, 2009 | 12:33 PM
well yeah that's true as well. i just figured that since this was the L61 forum i would throw some input about big ass TB's on n/a cars.
but i have also heard that the LS4 TB doesn't make that much more power on the LSJ's.
iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiidk though
ThoR294
Oct 4, 2015 08:44 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
ThoR294
Sep 28, 2015 05:31 PM
