2.25 or 2.5" exhaust, need opinions
Once all my parts are installed, for mods I'll have:
-wai, 2.4l intake man, balt ss injectors, 68mm TB, 4-2-1 tsudo header, tuning tuning tuning
My exhaust is still stock, and will have to wait until I do the IRS (Olds Olero independent rear suspension/disk brake swap, jbody swap to get rid of torsion axle) as the exhaust will be routed differently..anyhow, been pondering 2.25" or 2.5".. right now I'm building NA but i MAY get a GMPP supercharger kit in the future, so I'm leaning heavily towards 2.5"...I've also heard there is not a lot of low-end loss running 2.5" for city/daily driving. Opinions?
With a 2.5 exhaust and a 2.4 IM there will be a significant reduction in the low end. But if you are supercharging later it might be a good thing to have the bigger exhaust for later.
I'm not sure that you will need the 2.0 injectors though. There is no point in putting those on your car if they aren't needed.
A 68mm TB is likewise not needed.
The 2.0 injectors are not only needed but mandatory with the 2.4L intake man...unlike balts, the jbodies don't have a MAF sensor and do not adjust to the intake man correctly and lean out/detonate due to the air/fuels... this can be fixed with tuning, but the 2.0 injectors help the problem as well are needed once past the basic breathing mods. Why is the TB not needed? The 2.4 intake will be pushing more air, and a larger TB will no doubt help, combined with the header and other breathing mods.
Also on the exhaust size, the 2.25" will be perfect for both applications. 2.5" will suck for NA and make a minimal difference on just the basic M62 kit. Now if you plan on exceeding 250whp then yeah 2.5" would be good but your not going to see that on the stock pulley. Stick with 2.25", it will treat you right on your current mod list, and future.
Your going to lose power with the larger throttle body.
Sorry, disagree and I have past experience running larger TB's, if you go too large then yes it's a problem, 68mm is a small upgrade. Or if you put a larger TB on a car with stock breathing mods. The injectors are needed, not going to argue there, already seen many have to use them, remember I don't have a balt. And I'm going with 2.5" exhaust... the feedback I've gotten here and on jbody/saturn sites is the eco engine already has good low end so the 2.5 does not effect it that much (provided you don't remove the cat or run a highflow cat). I always get custom compression bent exhaust so it won't be a true 2.5" anyhow, it will be somewhere in between
So your telling me your going to be flowing more air then a fully bolted LE5? You do realize the LE5 aka 2.4 runs the same injectors as the L61(at least on the cobalts). So by adding a 2.4 intake manifold your going to be magically flowing more air then the 2.4? I dont think so... Thats why im telling you the injectors are not needed. Who cares if the 2.4 leans your car out, that has nothing to do with the injectors and everything to do with the tune. It doesnt matter if its a cobalt, its still an 2.2. The injectors are not needed at all is what im saying, but if you want to spend the money, go ahead
importkiller
Sep 30, 2015 07:18 PM
