2005 2.2 turbo
i know huh....aint that some ****....well i put a scanner on it and i got code p0315 which needs a crankcase relearn...which that has been there for a while now....but that was it...so im not worried about that....so it could only mean that my timing was off...so i just re did my timing....im waiting for the seal to cure here in a few minutes im going to go start her....wish me luck
luck mang.. get a vid damnit lol
well just got back from trying to jump start it....somehow the battery died again....im going to take the battery back to autozone tomorrow so they can charge it or they can give me a new one....its all good cuz i just got it...and i have warranty on it
really sounded it like it wanted to start....
Last edited by mrsilent13; Dec 19, 2008 at 01:31 AM. Reason: Automerged Doublepost
im sure it is something simple...its not throwing no codes so im really not getting any hints at all...so im looking for a needle in a hay stack right now....if i cant get this working before new years...its going to the shop so someone else can look at it
Last edited by mrsilent13; Dec 19, 2008 at 02:09 AM. Reason: Automerged Doublepost
the capasitor is your problem. you are suppose to disconnect capasitors when not in use. this is coming form a local car audio shop. the guy their refused to sell me one because he said that they have started fires in cars and recommended me to get a high power alternator, which i did. i just need to get it installed.
im done ******* around....it seriously sounds like it wants to start....but nothing....im just going to take it to the pros as soon as i get some cash in my pocket...they can get the timing down right...obviously im ******* something up and its not starting....after i redid the timing...it sputters a bit more....but its not good....well i feel i have done everything possible....ill give it another try tomorrow before i move
if your still trying to check if the car is getting spark you can pull out the coil pack, stick a screwdriver in it, and have someone try to crank the car, youll know it is passing spark, do that to all of them, that should tell you which ones are working and which ones are not, or you could be a ***** and do it the bitch way and buy the screwdriver with a built in light ment to do this, but than whats the shock, i mean fun in that
p.s. get your car running and throw a intercooler on it, atleast a water to air or something to cool the air down
this is pretty much how i did it....piston 1 at TDC and then the crankshaft sprocket white tooth at 5 o clock and the the exhaust cam diamong or triangle cant remember at 10 o clock and the intake at 2 o clock....just like the book says it should be done.....and it looks like i failed again....but once i get my last paycheck from the marine corps..thats going to be a lil less than 5k..here in about 40 days or so...hopefully less im going to take it in to a shop...im done playing around
