200whp N/A?
Old Nov 25, 2010 | 01:35 PM
  #226
joshc.'s Avatar
Originally Posted by all_motor_mike
dude ur sig is awesome, wheres that clip from lmao.
yeah its for the 02-05 j-bodies. it should be a close fit for the cobalts. as soon as i can find a mock up car for them ill be build one as well.
mike
fixed can't forget the original LS Sports. Also they will fit any J-body with an ecotec swap from 95-05.
Old Nov 25, 2010 | 04:28 PM
  #227
all_motor_mike's Avatar
woops....... i wasnt sure if its was 02 or 03 all remember is when i first saw the cars in the lot over in germany on base, i though it was late 02 but must have been early 02, thanks for the other info though sir.
mike
Old Nov 26, 2010 | 12:33 PM
  #228
elecblue06's Avatar
i like to be conservative and not get ahead of my self u know. elecblue, u hit me up on jbody?
mike
nah i'm not on Jbody.. i just sent an email to you a few weeks back
Old Nov 26, 2010 | 04:36 PM
  #229
did i respond?
mike
Old Nov 27, 2010 | 02:24 AM
  #230
redcobalt07's Avatar
so how much power do you think an 06 with say GMPP intake and exhaust, lsj header and dp, 2.4 manifold, lsj throttle body, stage 1 comp cams, and upgraded injectors would make with a tune
Old Nov 27, 2010 | 02:30 AM
  #231
NWAE Cobalt's Avatar
175.
on a good day...with the right elevation...maybe...MAYYYYBE
but id say youll probly see 160
Last edited by NWAE Cobalt; Nov 27, 2010 at 02:30 AM. Reason: Automerged Doublepost
Old Nov 27, 2010 | 04:13 AM
  #232
Originally Posted by NWAE Cobalt
175.
are you serious? i made 168 with stock injectors and a 2.4 TB, you think that with cams, lsj throttle body, and larger injectors you'd only get 7 more hp? obviously a tune is on both cars but still only 175??
Old Nov 27, 2010 | 04:33 AM
  #233
Mr.N00bLaR's Avatar
That's what I would consider ridiculously high.., the dyno thread has some 2.2s as low as 11x,12x with mods. Good for you I 'spose
Old Nov 27, 2010 | 04:43 AM
  #234
wow thats just ridiculous
Old Nov 27, 2010 | 08:25 AM
  #235
huckernage's Avatar
larger injector wont give you any poney.
Old Nov 27, 2010 | 02:32 PM
  #236
well no but they will help with the extra air from having an LSJ throttle body, 175 just seems so low even with cams
Old Nov 27, 2010 | 02:47 PM
  #237
no not really, ur not gonna need bigger injectors just because u have a larger throttle body.
mike
Old Nov 27, 2010 | 02:58 PM
  #238
HunterKiller89's Avatar
your 168 is a happy dyno. i'd say youre at 155whp with what you got. maybe 160
Old Nov 27, 2010 | 03:30 PM
  #239
Mr.N00bLaR's Avatar
Now that I think about it... theres someone with full bolts on, tune, stg 1 cams that didnt make as much power to the wheels as you did nearly stock. Cant remember the name though, yellow car?
Old Nov 27, 2010 | 04:51 PM
  #240
huckernage's Avatar
you ll need larger injector only in boost application
i m cammed stg2 my injector are not maxed out. and i would like use lsj TB and it was not a option to me to run larger injector.
Old Nov 27, 2010 | 05:03 PM
  #241
well i made 168 on a dyno pack
Old Nov 27, 2010 | 08:50 PM
  #242
copson
I have full bolts ons and stg2 cams, with a bad afr i made 180whp...but thats also with a shaved cyl head and FULLLLL bolt ons in optimal conditions (the area i live in makes for happy cars )
Old Nov 27, 2010 | 08:51 PM
  #243
isnt a dyno pack with the wheels off? ya...doesnt count for **** in comparison to a wheel dyno
Old Nov 27, 2010 | 08:54 PM
  #244
what year is your car also?
Old Nov 27, 2010 | 08:59 PM
  #245
aw tom thats mean lol, its a 2007
Old Nov 28, 2010 | 01:15 AM
  #246
ya..mean but true
Really, any dyno numbers are irrelivant to a car run on a diff dyno. Dynos are really designed to test a car to see if its optimal power and check to see if tuning and parts up the power...using the same dyno you get those results...but due to variables between dynos, locations, hell...even days and time of year it gets to be kinda biased. For instance..the area I dyno in has great air, it is kept nice and cold, dense air and is at relativly at sea level... Also, tire size can have an effect (kind of like a different final drive ratio). SO when you start to think about it, although its a great tool, and we like to compare numbers....comparing them is kind of useless unless everyone dynos on the same dyno same day....
and blah blah blah hahahahaha
That doestn stop me from bragging about my numbers and making people jealous though
and just wait till spring time, when the car has a ported and polished head and a new dyno tune
Old Nov 28, 2010 | 01:21 AM
  #247
yeah but i've long since upgraded so oh well,
Old Nov 28, 2010 | 02:02 PM
  #248
Matt M's Avatar
I didn't read the whole thread, so maybe this has been mentioned already, but one of the problems with a 200whp 2.2 is that it will need to be revved to 10k+ RPMs to achieve this peak power number.
Old Nov 28, 2010 | 02:47 PM
  #249
not quite that high. but yea, expect to see 8k
Old Nov 28, 2010 | 06:11 PM
  #250
soundjunky's Avatar
I call B.S.
but seriously, come on.
