Adjustable tensioner on 2.2?
anyone running this on there 2.2 setup?
**Ive received a pm from zzp saying they believe it wouldnt work on a 2.2 so ive turned to you guys now
http://www.zzperformance.com/cobalt_...=447&catid=142
Ive been looking into finding one to use on my 2.2 I am running a c1-sc procharger on a 2.2 and was wondering if I could find one that could work on my setup.. as you can see below i spin the alternator in reverse with a non ribbed pulley on my 2.2. I'm going to run a 2.25 pulley on the procharger this spring and really need somthing like this because i know for a fact my belt will slip because I'm only 5 rib.. Any help to solve slipping problems would be very helpful! thanks.
whynot just run a bigger tensionor pulley, take out the one on it now, and swapit for a larger one??? but that tensionor wont work, bc the lsj tensionor is like 3 pieces, thats just the part that hold the pulley, doesnt bolt to the engine, just bolts to the alt bracket...so ur best bet would probably be to get a larger tensinor pulley, plastic ones are cheap too...like $8 each...so would be cheaper aswell....
Well my stock one is kinda eating away itself slowly and needs to be changed out. I need one that i can adjust the tensioner on so I can make the belt tighter than stock. are you just using your stock one on your 2.2 with the m62?
Not at the moment.. but i can send u some in a lil while. or i think someone has some in their build threads
Here it is on MP81s car but without the blower and belt
https://www.cobaltss.net/forums/show...&postcount=264
yeah i dont believe i have enough room for that style tensioner.
Im going to look into swaping it all over to the 6 rib 2.0 setup so well see how it goes.
