Bad Relay? Help?
Old Sep 30, 2014 | 05:20 AM
x8xViperx6x's Avatar
Originally Posted by Balto82
I forgot to say after I put the new harness on and the car didn't work/run. I put the good old harness on and it still didn't work with original harness. I took the harness off a year ago to re wrap it with black tape and zip ties and it work when I put it on then. so now both harness don't work?
Did you unplug battery before removing/installing harness? It could have blown fuses if you didnt.
Old Sep 30, 2014 | 05:22 AM
Balto82's Avatar
no high beams. at the fuel pump relay I tested power on my light with ignition on. im pretty new at this. so im not sure what im doing
Old Sep 30, 2014 | 05:24 AM
Balto82's Avatar
yes I always unplug the battery. checked all fuses with a fuse checker also.
Old Sep 30, 2014 | 05:27 AM
Balto82's Avatar
I wonder if theres some kind of warranty on these harness that I bought. was around a thousand for both
Old Sep 30, 2014 | 05:31 AM
Connect the negative side of your multimeter to the negative post under the hood, its located on the strut tower, and says negative(-) in green i believe. Then remove the fuel pump relay, and test each of the four terminals with the positive side of your meter. Remember that it should only read voltage when key is in the on position. I cant tell you the actual voltage it should read, but if you see voltage thats a start. Im guessing two should be positive and two should be ground, but dont quote me on that. So if the meter reads 0vdc its probably a ground (if key is on).
Old Sep 30, 2014 | 05:36 AM
Balto82's Avatar
that's how I tested it according to a online how to. I believe when I checked was around 12 volts? ill check again. I notice that on some relays get power on 2 and others 1?
Old Sep 30, 2014 | 05:39 AM
I believe there is also a fuel pump fuse, not sure the number but check that too. Also verify that you did not put the fuse/relay in the wrong spot, it is very possible to plug it in one pin off.
Old Sep 30, 2014 | 05:43 AM
Balto82's Avatar
yeah im only getting power to one post for fuel pump relay if that matters. relay for headlight? I only see fuses for headlight
Old Sep 30, 2014 | 05:46 AM
check voltage on the fuses too.
Old Sep 30, 2014 | 05:49 AM
the fuel pump has a fuse too, its a 15a fuse directly under the relay.
then check all four headlight fuses for power too. If they all have power, then it has to be something between the fuse/relay box to the light/pump itself.
Old Sep 30, 2014 | 06:27 AM
  #36
Balto82's Avatar
no power on the fuel pump fuse but fuse is good. also no power on hi beam or low beam where the fuses go. but for parking lamp I do get power.
Old Sep 30, 2014 | 06:46 AM
  #37
Balto82's Avatar
11.15 volts and one pin for relay
Old Sep 30, 2014 | 07:00 AM
  #38
Balto82's Avatar
wonder if it would help to use dielectric grease
Old Oct 2, 2014 | 07:19 AM
  #39
Balto82's Avatar
Def is the connectors that plug into under the fuse box. Today i cleaned with connector cleaner and used dielectric greese and the car is running. I am still have a problem with one high beam. So i think connectors just dont want to sit right. Ill probly still take it in but atleast not on a tow truck. Hope i dont hit a pot hole or something. Well damn atleast i know whats up
Old Oct 2, 2014 | 10:27 AM
  #40
Spanky's Monkey's Avatar
check that highbeam fuse.
Old Oct 2, 2014 | 10:57 AM
  #41
blueLNFftw's Avatar
Are you sure the fuse box is sat in correctly?
I have had this problem and one of the fuse box plugs was in, but it was off one connector on a whole side. Reset the fuse box on the connectors and it worked.
Old Oct 2, 2014 | 06:44 PM
  #42
Balto82's Avatar
It must be in there pretty good now. But i was just checking the high beams and get this when you pull the high beam switch back both high beams work. But when i turn on headlight only one high beam comes on. Both fuses get power now. I dont think that headlight harness connector is sitting right.
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
Trav3480
Sep 28, 2015 02:46 PM
Iceberg
Sep 28, 2015 01:31 PM
