Bad shaking I cannot figure out
Old Jul 18, 2010 | 01:45 PM
HolyJerex212's Avatar
Hey guys I got a big problem I'm almost ready to scrap my car and get a new one...
I have a bad shake in my car between 45-70.
I have brand new pads and rotors
Tires are balanced and alignment done.
Brand new shocks and springs.
Fresh brake fluid and brakes bled.
The shake is also intermitant.
Someone told me it could be the axles
Someone also told menit could be the bearing
Old Jul 18, 2010 | 01:46 PM
ls1fbody's Avatar
Haz l33t wheelz.
Check your axles, they shouldn't have any play in them.
Jack up your car, grab the wheel at 12 and 6 and try to move it. If it does, bearing.
3 and 9, shake it, could be tie rods.
Only if something is loose and has easy play, if you're moving the other wheel, you're pushing too hard.
Old Jul 18, 2010 | 01:48 PM
bbrewbaker's Avatar
Could be a bent wheel.
Have you tried putting the front wheels on the rear to see if the shake follows the wheels.
Old Jul 18, 2010 | 01:50 PM
EatonTVS07's Avatar
I had a similar issue, saw grease around my outer tie rod so i replaced it and it stopped mostly, still need an alignment.
Old Jul 19, 2010 | 10:10 PM
Axles have no play.
Wheels have no movement at all.
I think it could be the new rotor might just be defective cause now i noticed when I brake its more noticeable and the more I brake the more I feel the shake...guy I know thats been a mechanic for 15 years said I should have them cut even though they are still newish (less than a week old)..
Also when I drive in the am everything is fine but if I make a slight left turn like a curvy road I start to feel the shake...any ideas guys? I'm ready to scrap this car :-/
Old Aug 1, 2010 | 01:10 AM
Cobalt08LS's Avatar
i had the same issue. my rotors and drums were heavily warped. i got them resurfaced and it seems to be fine now i got an alignment too
Old Aug 1, 2010 | 01:11 AM
springerdesigner's Avatar
isn't there a TSB for the steering column causing this..?
Old Aug 1, 2010 | 02:20 AM
Nighthawk243's Avatar
I know my one tire has a slow leak, and when it starts getting too low, my wheel shakes until I fill it.
Old Aug 1, 2010 | 02:22 AM
northvibe's Avatar
also could be the bearings in the steering rack.
brandon04
Oct 21, 2015 07:04 AM
Oct 13, 2015 09:32 PM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Iceberg
Sep 29, 2015 12:33 PM
