Coolant Temp Sensor
Old Feb 18, 2011 | 10:16 AM
MP81's Avatar
Coolant Temp Sensor
So my car had a kind heart to tell me the engine was at "---*F" yesterday on my drive home. About 5 minutes into the drive, the CEL popped on. Ran completely fine, no strange noises, nothing out of the ordinary, other than no coolant temp reading.
Started it up this morning, still had no temp reading, still had a light. Two minutes into my drive, I look down and my coolant now miraculously has left "---" and returned to a normal temperature reading...
What the hell is causing this? CTS going bad? If so, where is this lovely sensor.
And no, I haven't gotten around to reading the code.
Old Feb 18, 2011 | 10:38 PM
joshc.'s Avatar
CTS is on the back side of the engine near the thermostat I believe just below it. Probably a faulty reading.
Old Feb 20, 2011 | 10:00 PM
jerzeynomad's Avatar
Same thing happened to me twice. Both times it came back after a day or two. No idea on why though
Old Feb 20, 2011 | 10:02 PM
MP81's Avatar
Yep, CEL went away yesterday morning...totally got me!
Old May 13, 2011 | 01:06 AM
u0nlylive1nce's Avatar
So it's been 3 months since the last post on this. Has anyone fixed the problem? I have the same thing going on now.
Old May 13, 2011 | 09:43 AM
Phil424's Avatar
I have 50k on mine never had an issue. I have read about this many times before seems to be another common problem along with the end links going out on these cars. I wouldn't worry about it until it doesn't work at all completely. When it stops working its easy to replace and not that expensive. If you don't replace it you might have problems with the fans turning on and other emissions related things that operate by using the temp of the coolant.
Old May 13, 2011 | 10:03 AM
MP81's Avatar
It's been too flakey as of late for me to be comfortable with it - plus, when it goes out, the car has no clue what temp it is, and runs the fan, and lowers gas mileage.
What's the correct P/N for the sensor? I found two part numbers, and can't decipher which one is the right one...
Old May 13, 2011 | 12:12 PM
Phil424's Avatar
Autozone part number is SU112. ACDelco number is 2134514
Old May 18, 2011 | 11:37 PM
MP81's Avatar
Woot. Thanks.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
