Does the motor pull out the top or bottom?
pull the head off with the motor in, and then drop the motor out the bottom. I have access to a car lift. if your just changing pistons you wont have to remove the block. what r u doing?
he says in the original post... he got newer motor and tranny. so obv replacing his original motor and tranny.
Cobalt is easiest to do from the bottom. Unbolt the subframe and lift the car off.
GM Performance Division :: Performance Pulse :: Tech Manuals
See the LSJ power manuals at the bottom. Chapters 1 and 2 go over removing the engine.
Thanks guys...i had a blown head gasket on mine and i figured if i was gonna mess with the motor that was in there i might as well rebuild it cuz it had 115,000 miles, well i ended up finding a motor and tranny with 26,000 on it for $400 so i couldnt pass it up..thx again for the help
ThoR294
Oct 4, 2015 08:44 PM
