Does the motor pull out the top or bottom?
Old Mar 27, 2011 | 07:23 PM
kqst786's Avatar
Got a motor and transmission with less miles, does it pull out from the top or from the bottom?
Old Mar 27, 2011 | 07:24 PM
kikal8's Avatar
wow.. haha
Old Mar 27, 2011 | 07:26 PM
kqst786's Avatar
some are easier to come out the bottom.....
Old Mar 27, 2011 | 07:32 PM
kikal8's Avatar
ha u can do either. if your taking out BOTH the tranny and motor id do the bottom but ur probobly gonna have to remove ALOT more parts than if you were going to just take out the motor from the top.
Old Mar 27, 2011 | 07:34 PM
harryresh's Avatar
pull the head off with the motor in, and then drop the motor out the bottom. I have access to a car lift. if your just changing pistons you wont have to remove the block. what r u doing?
Old Mar 27, 2011 | 07:35 PM
kikal8's Avatar
he says in the original post... he got newer motor and tranny. so obv replacing his original motor and tranny.
Old Mar 27, 2011 | 07:36 PM
kxrida2000's Avatar
from bottom /thread
ive swapped 5 cobalt engines
Old Mar 27, 2011 | 07:38 PM
whyyoumadson?'s Avatar
from the bottom if doing the engine and trans together. i have access to a lift so yeah easy.
Old Mar 27, 2011 | 07:43 PM
Zero6LS's Avatar
Bottom. Just drop the sub frame but disconnect all the other parts first
Old Mar 27, 2011 | 07:50 PM
Nighthawk243's Avatar
Cobalt is easiest to do from the bottom. Unbolt the subframe and lift the car off.
GM Performance Division :: Performance Pulse :: Tech Manuals
See the LSJ power manuals at the bottom. Chapters 1 and 2 go over removing the engine.
Old Apr 1, 2011 | 11:04 AM
kqst786's Avatar
Thanks guys...i had a blown head gasket on mine and i figured if i was gonna mess with the motor that was in there i might as well rebuild it cuz it had 115,000 miles, well i ended up finding a motor and tranny with 26,000 on it for $400 so i couldnt pass it up..thx again for the help
Oct 20, 2015 09:56 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
Tupp
Sep 30, 2015 08:18 PM
ThoR294
Sep 28, 2015 05:31 PM
