Which Downpipe?
Old Mar 20, 2008 | 08:15 PM
gtxsport11's Avatar
Which Downpipe?
What downpipe is best for the 2.2?
Right now my setup is a DC Sports Header SS/SC DP and a DC Sports Cat Back Exhuast
Which is better Catless or a High Flow Cat?
btw i do not want it to sound raspy
Old Mar 20, 2008 | 08:28 PM
XM15's Avatar
If you don't want it to sound raspy, go with a high flow cat. I would look at CA or ZZP.
Old Mar 20, 2008 | 08:30 PM
gtxsport11's Avatar
ok thanks bro and i do not know if my aeroforce interceptor gauge is right or not but when i kick it reads almost 150hp do you think that that is correct for my mods
Old Mar 20, 2008 | 08:40 PM
XM15's Avatar
That sounds about right. With an intake, 2.4 manifold, and full exhaust you should be right around 150 give or take a few ponies.
Old Mar 20, 2008 | 08:43 PM
gtxsport11's Avatar
yeah well what can i do not besides boost to bump me up to about the 200hp mark do you know?
Old Mar 20, 2008 | 08:47 PM
XM15's Avatar
In order to get to 200whp you would have to do some major modifications.
Something like this:
Patriot Performance Stage 2 Head
Upgraded valvetrain for high revs (Probably 8K)
Higher compression pistons
Stage 2 or 3 cams
Tuning capabilities
Or, you could just buy a 75 shot of nitrous and save yourself the hassle.
Old Mar 20, 2008 | 08:49 PM
pacific cobalt's Avatar
I got 152 HP @ 6300 Rpm's on my Aeroforce Gauge so Yeah that sounds right since our mods are similar
Old Mar 20, 2008 | 08:50 PM
gtxsport11's Avatar
do you think that my 2.2auto is gonna be safe with a 75 shot?
Old Mar 20, 2008 | 08:57 PM
XM15's Avatar
The convention seems to be that you can run a 50 shot all day long, and use a 75 shot pretty frequently as well. It took a much bigger shot to break the rods in the 2.2 when GM did their testing. (IIRC ~150)
Old Mar 20, 2008 | 09:01 PM
gtxsport11's Avatar
ok thanks for the info i will prob give that some major thinking about goin spray
Old Mar 20, 2008 | 09:05 PM
XM15's Avatar
Here is a good place to start:
https://www.cobaltss.net/forums/nitrous-oxide-51/what-you-need-run-nitrous-look-here-95114/
Old Mar 20, 2008 | 09:07 PM
gtxsport11's Avatar
is it best to use a wet or a dry shot?
XM15's Avatar
Wet FTW
Thats why Stage 3 uses a Dry shot. Good old GM.
Old Mar 20, 2008 | 09:09 PM
TALON's Avatar
a wet shot is a lot safer than dry!!!
therefore most will say it is better!!!
Old Mar 20, 2008 | 09:11 PM
gtxsport11's Avatar
ok thanks bro and i checked out patriot perfromance they have some good stuff for the 2.2 thx for all of the info
hope to break the 200 hp mark soon in a ls
Old Mar 20, 2008 | 10:51 PM
XM15's Avatar
Just be warned that unless you are going to seriously increase your redline, or go f/i, the Patriot heads won't be maximized. I believe Ion ninja has a stage 2 head, and he mentioned that his powerband had shifted to the higher RPMs quite drastically. Low end performance is greatly reduced if you stay n/a. If you don't want to dig too deep, go with the nitrous.
Old Mar 20, 2008 | 11:24 PM
tru2nrtt777's Avatar
Dude you have to have a cat, you are in NC.
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
09SSlow
Sep 28, 2015 12:37 AM
riceburner
Sep 27, 2015 11:10 PM
