Few questions....
Old Nov 19, 2005 | 09:12 PM
TxCarGuy's Avatar
Few questions....
Hi. I have been thinking about a few things lately and I'm hoping that some of you have the answers to my questions. First of all is the lack of a voltmeter in the dash. I had an S10 before my Cobalt and the voltmeter definately saved me from being stranded in the middle of nowhere and I would like to add one to myCobalt. Has anyone added one to their car before? How hard is it? And has anyone replaced their fuel filter yet? Where is it and how hard is it to replace? Thanks in advance
Old Nov 19, 2005 | 09:23 PM
Cobalt_Supercharged's Avatar
A volt meter should consist of 2 wires and a gauge. It go right on to your battery terminals, run the wires under the carpet and door sills, and mount the gauge where ever. Or get a SS S/C A pillar pod and mount the gauge in there.
No clue on the Fuel filter sorry.
Old Nov 19, 2005 | 09:25 PM
NJBLUESS's Avatar
I have not added a voltmeter, but it would not be hard. You need to tap into the alternaters power wire to get a reading. Wiring and instulation instructions would come with a meter. Voltmeters are not that common anymore because of "idiot lights", it's also cost effective for the manufacturer to not have one.
As for the fuel filter, it's inside the fuel tank integrated into the fuel module assembly.
Old Nov 19, 2005 | 10:52 PM
WopOnTour's Avatar
Besides the "idiot light" and the digital voltmeter available through the Driver Information Center (DIC) the Cobalt's DIC will also display "CHARGING SYSTEM FAILURE" when any issue might arise
WopOnTour
Old Nov 19, 2005 | 11:13 PM
Clmbngfrk18's Avatar
im thinkin of puttin a voltmeter in my car just for system monitering to see how much im drawing at a time but how many miles on you car you shouldnt need a fuel filter yet i dont think
Old Nov 19, 2005 | 11:45 PM
TxCarGuy's Avatar
WopOnTour
Thanks for the information. I didn't know that it would alert me if there were ever any problems. And how often should the fuel ilter be replaced on this car? I replaced the one on my old S10 every 15-20k miles. Thanks
Old Nov 20, 2005 | 02:21 AM
dnbguy86's Avatar
Um, im not gonna flame you to bad here, but maybe you should look for the fuel filter before giving out random, wrong advice. If you look under the rear of the car, perferably by the fuel door underneath the car, you will see the fuel filter sitting there plain as day. Just trying to clarify the misinformed location.
Old Nov 21, 2005 | 07:04 PM
NJBLUESS's Avatar
I stand corrected, the filter is located externally and is serviceable. My apologys for being mistaken.
Now as far as giving out "random, wrong advise", I feel you should retract that statement. Here is where I obtained my information.
GM TECH Link, January 2005, Volume 7, no. 01 page 5.
Quote; "FUEL FILTER REPLACEMENT - Some customers have commented that they have been advised to replace their vehicles fuel filter periodically.
On many vehicles, the fuel filter is non-serviceable ( see table). The filter is an integral part of the fuel pump module and fuel pressure regulator assembly. The filter can be serviced only by replacement of the fuel module assembly. This process requires the removal of the fuel tank (one to two hours of labor, depending on the model), plus several hundred dollars in unnecessary parts.
The vehicles owner's manual outlines the periodic maintenance service required, under the Maintenance 1 and Maintenance 2 guidelines. Routine fuel filter replacement does not appear on either of these schedules.
In the future, due to the increase regulation of eveporative emissions, fuel systems utilizing a non-serviceable filter will become more common as new models are introduced."
Vehicles with Non-Serviceable Fuel Filters
CHERVROLET
2003-05 Corvete
2004-05 Malibu and Maxx, Silverado*,Tahoe**, Suburban, Avalanche
2005 Equinox, Cobalt,Aveo,Trailblazer and EXT, SSR
GMC
2004-05 Sierra*, Yukon** and XL
2005 Envoy,XL and XUV
PONTIAC
2003-05 Vibe
2005 G6, Pursuit***, Wave***
BUICK
2005 Rainier
CADILLAC
2005-05 XLR, Escalade, EXT, and ESV
HUMMER
2006 H3
SATURN
2002-05 VUE
2005 ION
* 2004 V8 only (4.3l USES CONVENTIONAL EXTERNAL FILTER)
** 2004 RPO L59 uses conventional external filter
*** Canada Only
So as one can see I do not post " Random Information". The system was changed without my knowledge. Again I appoligize to those on this post for " Relaying" improper information!
Old Nov 22, 2005 | 09:18 AM
Halfcent's Avatar
I'm old school
Way to go NJB! I love having service manuals qouted, even when they are wrong!
In which case, you would want an AMP meter, not a voltmeter.
danny84b
Aug 7, 2014 10:40 PM
baltman51
Jul 9, 2014 11:55 PM
Dfields
Jun 7, 2013 02:53 PM
JetBlackSS
May 28, 2011 03:12 AM
