Header install and now o2 codes
Old Nov 20, 2012 | 02:50 PM
GoofyBalt's Avatar
So this has been an ongoing problem that I cannot seem to fix
I installed a header and right after got the following codes
P0132 and P0135
Well ive replaced the front o2 with 2 different sensors and the codes still wont go away. The wiring on the plug is also fine. I just realized though that my header is touching the coolant pipe, do you think this could be grounding it out making it malfunction?
Thanks
Old Nov 20, 2012 | 03:11 PM
Jn2's Avatar
Jn2
P0132 and P0135
Thanks
doubtful, the 02 sensor is self grounded, thats why it has 4 wires. heater, ground, 0-1v, and a reference iirc...your problem is not the header touching the pipe.
Old Nov 20, 2012 | 03:28 PM
startingline05's Avatar
Maybe you have a short somewhere? I would just delete the codes so you never see them again lol
Old Nov 20, 2012 | 03:29 PM
GoofyBalt's Avatar
Well i cant just delete them. Vince is tuning my car and p1032 is cause my car to run extremely rich so before we go forward with the base map I need to solve this problem.
Old Nov 20, 2012 | 03:34 PM
Of course you can. Or some black electrical tape so you cant see the light anymore
BUt good luck
Old Nov 21, 2012 | 08:36 AM
GoofyBalt's Avatar
Thanks im sure ill need it
Old Nov 21, 2012 | 08:54 AM
isn't this why people get tuned?
Old Nov 21, 2012 | 11:01 AM
GoofyBalt's Avatar
I dont think you understand, the car is running rich because the o2 is maxing itself out, this was before we even started tuning. Per Vince I need to fix this before we continue doing logs to update the base map. Tuning your car with problems will just cause more problems.
Old Nov 21, 2012 | 11:19 AM
oh ok, i just thought whenever you change a part on a car, such as an exhaust piece, its gonna be running a little different. i've had an exhaust code for a while now with no issues, just thought i could get that code erased when i get tuned
Old Nov 21, 2012 | 11:59 AM
GoofyBalt's Avatar
Well it can but it depends on what code its throwing, did you pull it? Mine is maxing the o2 out meaning its grounding itself out somehow.
Old Nov 21, 2012 | 12:53 PM
Staged07SS's Avatar
Administrator
Administrator
You shouldnt just get a code erased when u are tuning....
Look into whats causing the code in the first place. If it is the P0420 code than, yeah just erase it. That code does nothing in terms of altering the tune.
Also, when u change parts on the exhaust side a tune is not really required.
Although, tuning for your mods is always beneficial in the long run.
Old Nov 21, 2012 | 01:51 PM
GoofyBalt's Avatar
Wow an informative post in a thread thats asking for one, ZOMG my head just exploded!!!
Old Nov 21, 2012 | 06:02 PM
nhanson's Avatar
Check condition of wiring..all of it. Also the connector plug.
Old Nov 21, 2012 | 08:24 PM
dannysauer's Avatar
I would go and get the o2 from the dealer I had lots of issues with anything other then dealer o2
Old Nov 21, 2012 | 09:29 PM
GoofyBalt's Avatar
ive tried 2 bosch sensors i bet its the wiring
Old Nov 25, 2012 | 01:41 AM
scagnetti76's Avatar
you are running rich. it could be anything from an intake leak behind the the MAF to an exhaust leak(pre cat). dont throw money at sensors utnil you know what is burning them up....
here is my guess ... you have CNP ignition. Your problem probably starts with an A..and end with dvance.
Or as we call it"round hear"?...,tune issues
Old Nov 25, 2012 | 04:01 PM
jdn902's Avatar
he already stated problem started prior to tuning.
unless i misread of course
Old Nov 26, 2012 | 09:24 AM
GoofyBalt's Avatar
Someone read my post, WHAT? i guess 2012 is really here!!!
This problem started when i installed the header, so its either the wiring or the fact that the header is touching the coolant pipe.
turbochargedss2012
Sep 20, 2023 12:17 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
