Injector's
Old Jul 12, 2009 | 03:04 AM
gomedan1's Avatar
Injector's
Ok, i heard that number 32 injectors off of a 2.0L SS/SC can be put on a 06' 2.2L, is this true? If it is where could i purchase these injector's and would i need a tune?
Old Jul 12, 2009 | 03:09 AM
xCobalt05x's Avatar
yes, it is true, but you need to tune the car as well. you can go as large as 60lb injectors. the 2.2 ECM is capped at 52lb injectors, how ever i have 60lbers in my 2.2 and vince was able to tune for them. you just set the table to run a little lean because the 60lbers are going to let more fuel flow. he commanded mine to run a 12.8 AFR but because of the 52lb cap and im running 60's, my AFR Wideband is reading 11.6 a WOT.
Old Jul 12, 2009 | 09:13 PM
gomedan1's Avatar
Ok but where can i buy the 32# injectors?
Old Jul 12, 2009 | 09:44 PM
NJjon's Avatar
Advantages to bigger injectors?
Old Jul 13, 2009 | 11:34 AM
xCobalt05x's Avatar
go to www.zzperformance.com and you can order used SS/SC stock injectors from there.
the advantage of bigger injectors is that you can reduce the duty that is placed on the injectors. If you are running a fully bolted 2.2 plus port and polished head and cams, then you will need bigger injectors so that you dont max out the smaller injectors. if you max out the injectors you run a bigger risk of blowing the motor up.
Old Jul 13, 2009 | 12:33 PM
Jn2's Avatar
Jn2
go to the classifieds, they sell for 30-50shipped all the time, but u should know they do not add power, they do not do anything to your car..injectors supply more fuel when u have more air...a n/a car wont need a injector upgrade...unless u have some f/i or internal work...waste of money
Old Jul 13, 2009 | 03:44 PM
xCobalt05x's Avatar
what do you think a larger throtle body, a port and polished head, and cams do???? they let more air in, more air in means you need more fuel. if you have stock 2.2 injectors, you can max them out quick as shizzz once you start opening up the air flow like that.
Old Jul 13, 2009 | 07:36 PM
gomedan1's Avatar
If i get any kind of injectors will i need to purchase the wiring harness to or would my stock 2.2L wiring harness fit?
Old Jul 13, 2009 | 07:37 PM
gomedan1's Avatar
Old Jul 14, 2009 | 01:23 PM
hugemurph4's Avatar
you need the wiring harness too
Old Jul 14, 2009 | 01:26 PM
Jn2's Avatar
Jn2
he didnt say he had those mods he just said i want bigger injectors..no reason given...
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
