installed header now coolant leaks?
Old Sep 16, 2009 | 11:48 AM
jonxxxedge1's Avatar
how do i rotate that pipe where its leaking from???
Old Sep 16, 2009 | 03:11 PM
07cobaltguy's Avatar
what pipe? what you said is extremely vague.
Old Sep 16, 2009 | 03:33 PM
Jn2's Avatar
Jn2
u mean the pipe that goes right under the header??? big aluminum looking thing?
Old Sep 16, 2009 | 03:35 PM
STS2/SS's Avatar
J b weld
Old Sep 16, 2009 | 10:10 PM
lwpmoon's Avatar
If that crossover pipe is touching the header that you installed chances are you did the same thing I did. The pipe has been pushed down and the header must be ground down enough to clear it. And since it has been pushed down it will need to be resealed. Just out of curiosity are you an 06?
Old Sep 16, 2009 | 10:47 PM
yeah im an 06
Old Sep 18, 2009 | 06:18 PM
lwpmoon's Avatar
So GM did do something stupid... I'm an 06 a I have had problems with the exhaust mani and the down-pipe specs being completely different from all other cobalts.
https://www.cobaltss.net/forums/show...80#post4311880
Same is true with the exhaust manifolds. I cant think of any reason they changed it... and then changed it back.
Old Sep 18, 2009 | 06:52 PM
PsychoCam's Avatar
my hahn turbo mani went on fine but when tightened down the whole way pushed on the coolant pipe causing it to leak from the seals so i ground down the header a good bit and it still did not work so I had to take off the coolant pipe heat it up and hammer it down some then re install.
had no problems since : )
Old Sep 18, 2009 | 06:54 PM
OneSlowGto's Avatar
Same thing happened to mine when i had my cobalt and zzp sent me a new header. Fit fine after that
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
justinchinn
Oct 2, 2015 12:18 PM
riceburner
Sep 26, 2015 12:57 AM
