MP81's Supercharged L61 Build
Old Aug 1, 2009 | 01:20 AM
  #451
MP81's Avatar
Well, that's odd - looks like when I put it into L, I still get traction controlled...where it limits the RPMs cause it's spinning too much.
Looks like that's getting turned off completely.
Old Aug 6, 2009 | 11:20 PM
  #452
MP81's Avatar
So, what is your guys' idle quality like?
I can feel the car idling, but it's not like it's missing.
Old Aug 7, 2009 | 04:34 AM
  #453
HunterKiller89's Avatar
it feels...heavier..than stock. Otherwise, its the same. It also sounds harsher on cold starts
Old Aug 7, 2009 | 11:55 AM
  #454
MP81's Avatar
Yeah - you can hear my supercharger a little, but when it warms up, it's fine. Which seems normal.
Okay - so my idle is normal then. I can't see my needle move, so I think it's good.
Old Aug 10, 2009 | 12:11 AM
  #455
MP81's Avatar
All righty, so Vince tweaked my tune a little to richen up WOT, could possibly go a bit more - but holy **** the difference that made...I don't even know how, but it feels much faster...
Still trying to figure out this other issue I'm having...cause I can put the pedal down about half and PE will kick in, but usually if I nail it from there - PE turns OFF...
I also was thinking about possibly switching gauge clusters in the future to an SS unit, so I can have a bit higher reading of speed, since my car will certainly go over 120 (with tires that are rated for above 120)...does Vince have to change something for the new cluster or will it just work?
Old Aug 10, 2009 | 03:42 PM
  #456
i dont believe theyre compatable, as the LSJ and L61 use different architecture ECM/BCMs. You're best bet for a plug and play swap would be one from a LNF, as they also use a CAN bus syetm
Old Aug 10, 2009 | 03:45 PM
  #457
Jn2's Avatar
Jn2
O_o i wrote the how to on the swap :p everyone told me the same thing, wont work wont work, well i loved proven almost the entire board wrong :p 05-06 all cluster are interchangeable...07+ must swap with 07+ clusters of all models...havent had exp with the LNF one yet....but im running a 06 2.4SS
Old Aug 10, 2009 | 07:35 PM
  #458
Gene Culley's Avatar
Talking
I guess I lucked out as mine is already at like 140 or 150.
Old Aug 11, 2009 | 12:57 AM
  #459
MP81's Avatar
So I should be okay with an '07 SS/SC cluster then?
Old Aug 11, 2009 | 02:04 AM
  #460
are you referring to the LSJ 160mph, or the 140mph one, because the LE5 also uses a CAN bus system, whereas the LSJ uses a PT bus
Old Aug 11, 2009 | 08:57 AM
  #461
stenguyen1's Avatar
i have an 06 ss gauge cluster in my car now. it depends wat year is ur car and the gauge cluster. if its the same year its likely plug and play.
Old Sep 10, 2009 | 01:21 PM
  #462
MP81's Avatar
So...plugs...
Will NGK BKR8EIX Stock number 2668 work?
Or is there something else that would be recommended?
I only have 37k on the stock plugs, when should they be changed? Maybe I should pull them and check the color.
Old Sep 10, 2009 | 11:02 PM
  #463
Talking
When you went SC you were supposed to change them. I bought the plugs suggested in the how-to and found out yesterday that they are also 1 step colder so it is a plus. I ordered them from Amazon.com because it was a good deal with shipping.
NGK LFR6A-11 Spark Plugs
Old Sep 10, 2009 | 11:07 PM
  #464
MP81's Avatar
Casey mentioned he ran his stockers for a while.
Are the ones you got Iridium? What gap did you run?
Old Sep 10, 2009 | 11:17 PM
  #465
Talking
They are not Iridium. I believe they are copper or something as they say that is better for supercharged cars. I left the gap at .040. Many use variants between .035 and .040. Mine seem ok where they are though.
Old Sep 11, 2009 | 12:00 AM
  #466
MP81's Avatar
I think if I remember, I'll pull my plugs tomorrow and check the color and post it up here...
Old Sep 11, 2009 | 02:49 AM
  #467
yep. i ran the stock plugs for about 2-3 weeks and everything ran fine. no knock, no misfores, no nothin.
Old Sep 11, 2009 | 02:50 AM
  #468
MP81's Avatar
Cool, I've had them in for a few months and it seems to be fine.
Old Sep 27, 2009 | 05:25 PM
  #469
MP81's Avatar
Man - gotta update this ****.
Been a while - but I think the tune has finally been fixed, as I haven't had that roll-into-WOT lean out anymore! Who knew that breaking the law could fix so much ****. Going 110 back from B-dubs tripped a MAP High-voltage code. I had Vince tune out the MAP high voltage check, as well as traction control - and bam, the Power enrichment issue went away (hopefully).
...and no traction control is amazing - though it still seems to cut me off after a while anyways, but it doesn't seem to be as early anymore...
My front Continental tires had 1/16" of tread left, so I decided it was time to get them replaced.
Bought some Yokohama AVID Touring-S 195/60R15s from Discount for $63 a tire (totalled ~$160 all mounted, balanced and installed).
Nice to have some tread - maybe I'll see a mileage increase too...
Here's a video I just took today:
http://www.youtube.com/watch?v=CaC8toplr28
That ticking is the injectors, I believe - my camera really picks up the sound, cause it's nowhere near that loud...
Old Sep 27, 2009 | 06:04 PM
  #470
mtbrent's Avatar
Damn dude, 195's and is that 620 treadwear rating?!?! You don't like traction do ya!!!
Old Sep 27, 2009 | 06:08 PM
  #471
cobalt123's Avatar
dang it man, now i had to post mine lol nice job
Old Sep 27, 2009 | 07:36 PM
  #472
MP81's Avatar
Yeah - the reason I went with such a high treadwear is cause these will end up being my snow tires.
And they actually aren't that much different from my almost-slick-like Continentals. But 15" rims with tires are gonna spin for the most part regardless.
Old Sep 27, 2009 | 07:53 PM
  #473
now, the rim size plays a factor here...but my 18's with a 215/35 (old tires) are the exact same size as the stock 15" steelies /w stock high profile continentals. With the continentals, i can spin out anywhere in 1st gear, whereas with my Nexen's, i wont break traction unless im doing less than 15mph
Old Sep 29, 2009 | 09:16 PM
  #474
Talking
Nice man. I'm glad to see it working out for you.
Old Sep 29, 2009 | 11:33 PM
  #475
MP81's Avatar
One thing I've noticed is my belt is really squeaky when it's cold out...
