MP81's Supercharged L61 Build
Old Sep 30, 2009 | 01:30 AM
  #476
mtbrent's Avatar
Originally Posted by MP81
One thing I've noticed is my belt is really squeaky when it's cold out...
Mine did the same thing all last winter when startup temps were below 50F. It only squeeked for a minute or so though, just til the engine bay warmed up.
Old Sep 30, 2009 | 02:16 AM
  #477
MP81's Avatar
That's exactly what mine does.
Old Oct 9, 2009 | 12:49 PM
  #478
MP81's Avatar
So, I wasn't supposed to do anything with the alternator, right? I mean, it seems to work just fine, but I remember reading about flipping wires earlier in my thread...
Old Oct 18, 2009 | 10:51 AM
  #479
Gene Culley's Avatar
Talking
Someone said that the SC setup changes the direction of the alternator, but I haven't had any issues and if you haven't, then I would let it go.
Old Nov 19, 2009 | 05:07 PM
  #480
jbenso4's Avatar
sub'd for my build!!!! good work!!!
Old Nov 20, 2009 | 01:06 PM
  #481
cobalt_driver's Avatar
x2. ive been deciding on whether i wanna dump any more money into my ls. i think i might though.
Old Nov 20, 2009 | 03:56 PM
  #482
HunterKiller89's Avatar
it does. The LSJ alternator has a clutch and only spins in one direction, but the L61/LAP/LE5 alternator can spin in both directions, so you dont need to do anything. Since it makes AC voltage, it doesnt matter if the wires are swapped or not either
Old Nov 20, 2009 | 05:29 PM
  #483
MP81's Avatar
Ahh, good to know!
Out of curiosity, what type of gas mileage were/are you getting, Casey?
Old Nov 20, 2009 | 06:22 PM
  #484
well, i have almost 100% city driving, and i was seeing around 22mpg. highway i would be in the 30's easy tho.
Old Nov 20, 2009 | 07:10 PM
  #485
Talking
Nice explanation, thank you.
Old Nov 25, 2009 | 03:05 PM
  #486
DCOBALTSS's Avatar
can someone explain to me whats a ic pump and heat exchanger pump
is it the same thing both and whats the function ofit
thanks
iM just a beginner
thanks/
its ok with some research now i know its the intercooler pump connecting the coolant etc
Another question arisein my research where do i check the IAT2 temp range
help plz
Old Nov 25, 2009 | 06:16 PM
  #487
MP81's Avatar
thanks
The supercharged Cobalts do not use an intercooler - they use a heat exchanger, and the heat exchanged pump runs the coolant through the heat exchanger and the intake manifold.
help plz
Aeroforce Interceptors can read the IAT2 temp.
Old Nov 25, 2009 | 11:23 PM
  #488
DCOBALTSS's Avatar
thanks for info.. and if i supercharge my car ill need the Aeroforce Interceptor
and.. regarding the build in some build info guide i saw ic pump..
so whats that for then
so will i need an ic pump or just the he pump
Old Nov 25, 2009 | 11:28 PM
  #489
MP81's Avatar
IC pump in this case would just be incorrect terminology for the heat exchanger pump.
Old Nov 25, 2009 | 11:33 PM
  #490
DCOBALTSS's Avatar
ok thanks for info
Old Nov 26, 2009 | 01:21 AM
  #491
mtbrent's Avatar
The Interceptor will not read IAT2 unless you use the stock lsj 2.5b tmap sensor and rewire it into the maf, where you can read it as iat1(even though you are actually seeing iat2 numbers).This is for the 2.2/2.4 only.
Old Nov 26, 2009 | 07:09 AM
  #492
this
Old Nov 26, 2009 | 02:49 PM
  #493
DCOBALTSS's Avatar
Please help beginner
hey mp81 i need ur help
heres my question:
Theres a radiator cap in front near the tb next to the supercharger on the picture i guess its for cooling but to what is it connected. and how
On my stock engine 2.4 i dont have it and
Does the 2.0 have an intercooler stock or something like that please help me thanks
Old Nov 26, 2009 | 03:35 PM
  #494
its the intercooler/heat exchanger coolant system for the supercharger
Old Nov 26, 2009 | 11:05 PM
  #495
DCOBALTSS's Avatar
so i will need to buy this too to supercharge my 2.4
does it come with the zzp cooler or
if its and lsj part whats the part number for it.
Old Nov 26, 2009 | 11:21 PM
  #496
either buy that or a option B tank or an inline coolant tank..your call.
Old Nov 27, 2009 | 12:07 PM
  #497
DCOBALTSS's Avatar
when you say tank you mean theother coolant tank that some people install in stage 2 kit someting like that right
or ive seen people having both of them that should be good too and better i guess..
hey does any one have something like this but with all the parts described and detailed if so let me know thanks i would like to learn more about each parts before i supercharge my 2.4
where exactly does the heat exchanger pump go? any pics to show me guys..
Old Nov 27, 2009 | 03:39 PM
  #498
the heat exchanger pump goes inside the heat exchanger pump bracket which bolts on to piece 906 in the above picture.
and no, no one runs the extra coolant tank (option B) AND the stock filler neck (option A). at the same time. the whole point of running the option B tank is to replace the opt. A neck.
Old Jan 16, 2010 | 07:29 PM
  #499
MP81's Avatar
Went and washed the car at a quarter wash to get all the salt and **** off. Still isn't like a good handwash at home, but it does the job.
Finally, a video. Sounds better in real life than the video. I really like the sound inside the car.
YouTube - SS/TC Catback Exhaust on Balto
Old Jan 19, 2010 | 11:06 PM
  #500
Talking
Looks good Kyle! How does it sound?
