MP81's Supercharged L61 Build
Old Feb 13, 2009 | 02:27 PM
HunterKiller89's Avatar
Originally Posted by MP81
Also, a couple other things...
How much boost is safe to run on the stock 2.2L bottom end?
I'm planning on a Auto Meter Cobalt Mechanical Boost gauge (was looking at the electric ones - but they're like $125 more than the mechanical), where would one plumb that to? And should I go Boost or Boost/Vac.
rods are rated at 250bhp. They snapped at 283bhp under nitrous. Ive seen as high as 300whp on stock rods/pistons under boost. The question goes to you...how much of a safety margin do you want to leave?
Originally Posted by IonNinja
Actually I lied I may be thinking of something else...
Either way I'm pretty sure you could rig something like that up...
you'll have to buy the LSJ reservoir. theyre the exact same shape, but mirror images of each other. theres no way to mount the stock one on the other side.
Old Feb 13, 2009 | 02:34 PM
MP81's Avatar
Well, considering this in my DD, a decent amount - but I still want power. I'd say maybe 200 whp? So about 225 hp at the fly?
Thought so.
Old Feb 13, 2009 | 02:58 PM
stenguyen1's Avatar
dang yet another person who is going supercharged. lol i will doing mine next weekend. might be postin up my build also.
Old Feb 13, 2009 | 03:08 PM
Thought so.
its whatever you want. I personally am around 260bhp, so 220whpish? but it all depends how hard you wanna push your car. Like i said, no one can make that choice for you
Old Feb 13, 2009 | 05:25 PM
MP81's Avatar
Well, how much boost are you running?
Old Feb 13, 2009 | 05:39 PM
bout 13psi
Old Feb 13, 2009 | 06:07 PM
DebadgedBALT77's Avatar
hunter, did you or does anyone have a build guide/how to for their 2.2 supercharged build?
Old Feb 13, 2009 | 06:11 PM
ColeJJones's Avatar
Bannned
woah woah.... 2.8 pulley!!??
Old Feb 13, 2009 | 06:14 PM
i made a how-to..?
to cole: almost...2.9"
Old Feb 13, 2009 | 06:16 PM
ColeJJones's Avatar
Bannned
another pound is a huge difference
Old Feb 13, 2009 | 06:26 PM
  #36
stenguyen1's Avatar
there are alot of how to's for supercharging a 2.2 just search it. hunterkiller made one that is good to go by. and beck made one for the 2.4
here is a thread
https://www.cobaltss.net/forums/forced-induction-50/supercharging-my-2-2-tomorrow-148202/
and another one
https://www.cobaltss.net/forums/how-guide-43/hunters-how-install-m62-2-2l-cobalt-127891/
Last edited by stenguyen1; Feb 13, 2009 at 06:26 PM. Reason: Automerged Doublepost
Old Feb 13, 2009 | 06:40 PM
  #37
meh
it felt noticeable...but the interceptor says i went from high 24Xhp peak 250hp up to high 25Xhp peak 265hp. a good 10-15 horses
Old Feb 13, 2009 | 08:05 PM
  #38
i searched, but only saw the 2.4 build? hmm, must not have used right key word phrase? no idea. thanks for the link!
Old Feb 13, 2009 | 08:43 PM
  #39
MP81's Avatar
What will the Stage 2 pulley make as far as boost goes? What about the 2.8? 2.7?
Old Feb 14, 2009 | 04:11 AM
  #40
3.0" made 11.5psi, 2.9" makes 13psi, so take a stab at 2.8" and 2.7"
stg 2 pulley is 3.05" fyi
Old Feb 14, 2009 | 08:18 AM
  #41
BlackCobalt707's Avatar
still need a boost gauge? i got a Faze for $20
Old Feb 14, 2009 | 03:45 PM
  #42
Jn2's Avatar
Jn2
u dont need that boost controller thingy, leave it out, just leave the bottom nipple open venting to atmosphere....the sensor ontop of the blower, u can leaveit there, but it wont plug into anything, the sensor on the intake manfold, take it out, and put ur MAP sensor in there, yo dont need the sensor you just took out, you need **** loads of 3/4" hose and 1/2" hose, you need a another coolant tank, ameks ure your TB harness has the same amount of pins as that throttle body, and than u still need to repin for that TB to fit...or else you might be stuck using your stock one, lemme see what else, you need 3 longer bolts for the alternator, you need to longer bolts for the intake manifold, you need of course a h/e, a intake manifold gasket for the head...thats it, there is other things, but im too lazy to really try and remember what all we ended up needed, i mentioned all theones that would of screwed u over if you didnt have the rest is self explanitory
Old Feb 14, 2009 | 05:44 PM
  #43
very good post. Im not sure what you used 1/2" hose for tho...all mine is 3/4". The bolts you need for the alternator are M8 1.25 threading and i think either 120mm or 130mm long. (measure the stock ones and add 20-25mm)
Old Feb 14, 2009 | 06:08 PM
  #44
Jn2's Avatar
Jn2
LOL we didn't use it good point, we bought it, just never used it :p
Old Feb 15, 2009 | 11:54 AM
  #45
beansirl's Avatar
my 2.8 makes around 15-16 or so
Old Feb 15, 2009 | 03:25 PM
  #46
boost levels should be different for 2.2's due to the extra displacement...tho those numbers sound ike theycould be 2.2 numbers too..lol
Old Feb 15, 2009 | 03:32 PM
  #47
MP81's Avatar
Numbers shouldn't differ since boost is measured before the engine .
Looks like I should stick with a Stage 2 pulley to be safe?
Old Feb 15, 2009 | 04:11 PM
  #48
blue 2.2's Avatar
Haha, that's the picture from the seller. I haven't taken all the stuff out of the box, so I just used his picture.
Looks like a golden retriever.
What do you mean flip my wires?
Will the stock H/E be sufficient, and how easily does it mount?
lmao your off big time buddy its a long hair Chihuahua its my mothers dog
Old Feb 15, 2009 | 04:14 PM
  #49
MP81's Avatar
Wow, I was off.
Old Feb 15, 2009 | 04:19 PM
  #50
StevesBlack06's Avatar
do not hack up your wiring harness get one off a cavalier/sunfire with a 2.2 eco
