MP81's Supercharged L61 Build
Old Feb 15, 2009 | 04:24 PM
  #51
blue 2.2's Avatar
Originally Posted by MP81
Wow, I was off.
look at the pic again the intake manifold is almost the same size as him man im so pissed i had to sell keep me updated on the build and seein the sc is ported wouldnt that effect the boost numbers to im not sure though
Old Feb 15, 2009 | 04:34 PM
  #52
MP81's Avatar
Ahh, I thought that was just part of the dog, haha.
Yeah, the porting should help.
I'm throwing around the idea of plugging the silencer holes...
Old Feb 15, 2009 | 04:38 PM
  #53
blue 2.2's Avatar
i was thinking about doing it but then i planned to just put it on the car and see how it sounded first and then do it later if i still wanted but we see how well that went lol
Old Feb 15, 2009 | 04:39 PM
  #54
HunterKiller89's Avatar
Numbers shouldn't differ since boost is measured before the engine .
Looks like I should stick with a Stage 2 pulley to be safe?
numbers should differ because the larger engine will take in more CFMs per stroke than the LSJ, leaving less left in the manifold, so manifold pressures will be lower.
easy explanation. Bolt up an M62 to a LS2 with a 2.5" pulley...you wont see much boost
Old Feb 15, 2009 | 04:44 PM
  #55
MP81's Avatar
Yeah, forgot to include that into my thoughts...
Old Feb 15, 2009 | 10:16 PM
  #56
stenguyen1's Avatar
so let me get this right. the map sensor on the sc we don't need to plug it into any thing right?
than wit the bolts of the intake manifold how long do they have to be to get it to fit the sc manifold? can i jsut get it at lowe's or home depot?
Old Feb 15, 2009 | 11:22 PM
  #57
my stock ones worked. sooh....
Old Feb 16, 2009 | 05:23 AM
  #58
alleged's Avatar
hurry up and get everything else op so we can see what kinda numbers you run!!!!
Old Feb 16, 2009 | 07:13 AM
  #59
MP81's Avatar
Haha, yeah, gotta decide on a H/E and then see how much money I have left after I pay my mom part of my tuition. I'm not installing till July most likely...
Old Feb 16, 2009 | 10:55 AM
  #60
IonNinja's Avatar
Originally Posted by HunterKiller89
The bolts you need for the alternator are M8 1.25 threading and i think either 120mm or 130mm long. (measure the stock ones and add 20-25mm)
why do you need longer alternator bolts?
Old Feb 16, 2009 | 11:26 AM
  #61
stenguyen1's Avatar
cuz when you put the new tensioner on with the bracket it bolts on the same as the alternator so you would need the bolts to be longer so they can tighten the tensioner bracket and alternator together.
Old Feb 16, 2009 | 11:55 AM
  #62
IonNinja's Avatar
ahh...kay
Old Feb 16, 2009 | 06:08 PM
  #63
MP81's Avatar
Does anybody know what if any H/Es will fit behind the stock front bumper?
I really do want to keep a low profile...
Old Feb 16, 2009 | 10:46 PM
  #64
^^ a cobra might...theyre pretty small
Old Feb 16, 2009 | 10:49 PM
  #65
MP81's Avatar
Yeah... I might have to take some measurements, though i'm not quite sure what to measure from and to.
Old Feb 17, 2009 | 09:08 AM
  #66
MP81's Avatar
And I do need another coolant reservoir?
The SS and 2.2 ones arent the same?
Old Feb 17, 2009 | 12:58 PM
  #67
you dont need one..no. Stock SS's dont have them...but it seems everyone who upgrades immediately buys one to run Opt. B. I would rather go with the hatrickstu mod or OTTP's coolant reservoir (effectively the same thing)
Old Feb 17, 2009 | 01:01 PM
  #68
MP81's Avatar
So I can just use my stock coolant reservoir then?
Old Feb 17, 2009 | 01:03 PM
  #69
YzRider452's Avatar
No, its a seperate system.
Old Feb 17, 2009 | 01:47 PM
  #70
the intercooler/HE system for the supercharger does NOT share coolant with the engine. they are two independently plumbed and operated units. engine coolant temp is near 180* whereas intercooler coolant temps are much closer to 100* and below (depending on ambient temperature and how much you're getting on the gas
Old Feb 20, 2009 | 08:23 PM
  #71
MP81's Avatar
Hmm, don't see that thing on GMPartsDirect...
So I need that.
Now just to make sure: The ONLY gaskets I need are as follows: TB to SC, SC to IM, IM to CH, right?
I also might have to roll with the stock H/E for the time being too.
Old Feb 21, 2009 | 12:40 AM
  #72
if CH is supposed to stand for the head...then yes
Old Feb 21, 2009 | 01:19 AM
  #73
MP81's Avatar
Yeah, I was too lazy to write everything out, haha.
Old Feb 23, 2009 | 09:35 AM
  #74
MP81's Avatar
I think I'm going to go with a stock heat exchanger at the beginning, unless I can find a heat exchanger that for sure fits under the stock bumper. A cobra H/E should fit, but I'd have to fab **** up, and I don't know if I'll be able to do that and do the swap in the weekend.
It's always something I can add later...
Old Feb 23, 2009 | 04:19 PM
  #75
PM steven_flit. He runs a cobra too, and its mounted in a way thats easy to do and should fit on a LS bumper too
