Rewiring for 2.4 TB
Old Aug 25, 2012 | 04:36 PM
iToastie's Avatar
Rewiring for 2.4 TB
So I've studied the diagram that's floating around here somewhere for a while.
I bought a 6-8pin LE5 to LSJ harness from ZZP.
Aparrently the LE5 and L61 6pin's are the same.
So I'm trying to rewire it so that the 8-pin side will work to a 8-pin LE5 TB.
I plugged in the 6pin side to my car now, and matched up the colors from the car side to the harness side, 2 or 3 wire colors are different.
How would I do this?
The colors in the diagram arn't the same.
Old Aug 25, 2012 | 04:52 PM
iToastie's Avatar
I'm an idiot and didn't see there are letters on each end of the connectors.
Old Aug 25, 2012 | 05:08 PM
huckernage's Avatar
Old Aug 26, 2012 | 09:27 PM
hugemurph4's Avatar
Wait does the le5 throttle body harness work with the 2.2 without wire modification?
Old Aug 27, 2012 | 05:21 PM
huckernage's Avatar
8 to 8 pins ll have no modification 2005 -2006
2007 use 6 pins
Old Aug 27, 2012 | 10:16 PM
scagnetti76's Avatar
Best way would be to locate connector end view pinouts from GM, and match functions of wires, not just color. Iirc the difference is an extra 5v refference signal and return on the eight pin. Solder and heat shrink. Done... Pinout is a pita to find though without all data or something similar.
Old Aug 28, 2012 | 12:55 PM
hugemurph4's Avatar
So I need to find an 05 06 2.4?
Old Aug 28, 2012 | 12:57 PM
hugemurph4's Avatar
Or does every year have 8 pin
Old Aug 28, 2012 | 03:58 PM
klotzy_550's Avatar
Did the harness end up working out for you? It came with my lsj TB adapter I bought from zzp, I used the adapter to use my stock 2.4 TB on my supercharger. So no need to use the harness, just needed to open it up to get the oring gasket.
red9
Oct 4, 2017 02:23 AM
Barkleyj605
Oct 24, 2015 12:07 AM
patooyee
Oct 15, 2015 05:11 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
