running s/c without h/e hooked up
Old 08-19-2012, 02:07 PM
ryman416's Avatar
is it possible to run a supercharger with the endplate not connected to anything? i mean just to get the car running, not boosting or anything.
Old 08-19-2012, 02:15 PM
08baltls's Avatar
I personally wouldn't. I mean at that point it would only be full of air and air heats up faster then coolant. You would probably run incredibly hot. Just look for a used one on here or buy one from one of the vendors. OTTP sells a new one for under $200. Eaton's put off a lot of heat and I wouldn't want to risk running one without having a way to cool it down.
Old 08-19-2012, 02:18 PM
nhanson's Avatar
Yes. I did this till i got my pump wired and plumbing done.
Old 08-19-2012, 02:51 PM
ryman416's Avatar
oh i already have the plumbing and h/e with the pump all installed. im just waiting on a tank and some hose fittings to install tomorrow and was just seeing if moving it into the driveway was possible without going kaboom. The other issue is the fact that im running incredibly too lean (16-18!!!) so im def not gonna drive it anywhere.
Old 08-19-2012, 03:53 PM
nhanson's Avatar
You will be fine.
Old 08-19-2012, 05:31 PM
ryman416's Avatar
yeah i got it in the driveway now. afr's are so high that my gauge was just like **** you. it said it on the display. weird.
Old 08-19-2012, 05:49 PM
Blowncavy's Avatar
You'll be fine
Gm warrenties the sc kit for the 2.2 cavy with no heat exchanger
Old 08-19-2012, 07:09 PM
08baltls's Avatar
Oh ok. I thought you meant like just the manifold with a blower on top and nothing hooked into it at all. Haha. And yeah just moving it around a little would be fine. I just wouldn't plan on driving it anywhere til it's all hooked up and running.
Old 08-19-2012, 07:17 PM
ryman416's Avatar
yeah, definitely not driving it anywhere till i get an updated tune. this one was kinda rough so far. hopefully vince can get it to run smoothly.
Old 08-19-2012, 07:48 PM
08baltls's Avatar
That could be a long an arduous road. I've flashed the first and then two updated tunes and am still not running 100% right. And Wednesday will be two weeks since I initially started the tuning with Vince.
Old 08-19-2012, 09:53 PM
ryman416's Avatar
looking forward to it hahaha
Old 08-19-2012, 10:32 PM
nhanson's Avatar
Sucks you have to use trifecta
Sl0wbaltSS
11-21-2018 11:11 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
OrangeCoba
10-01-2015 10:00 PM
dieGone
10-01-2015 06:27 PM
Extremespeed
09-29-2015 04:34 AM
Quick Reply: running s/c without h/e hooked up
