Strange Clunking Noise
Old Mar 10, 2010 | 01:14 PM
Pandru's Avatar
So I've got this strange clunking noise coming from the right front of the car, say if i don't shift smoothly the car will do the typical little jerk forward and i'll hear the clunk, I also hear the clunk if I let off the gas and then press the pedal quickly it will clunk. I'm suspecting a possibly bad control arm bushing or maybe a bad motor mount? I've already replaced the left front control arm bushing but can't recall if it was making the same noise/having the same symptoms. Thanks for any advice guys.
Old Mar 10, 2010 | 01:25 PM
Hawaiian Whore's Avatar
yeah, sounds like a motor mount or transmission mount
Old Mar 10, 2010 | 01:46 PM
xxxxsh4d0wxxxx's Avatar
Yes, sounds like either the trans mount, or motor mount. A control arm bushing would only get that bad over a bump, or a shitty road. Not clunking all over from rough shifting, or letting off the gas and hammering it. You're really not using the control arms room of travel to move enough by doing either of those to make it clunk.
A bad trans mount is fairly easy to spot, and is a likely candidate. Take a flashlight and give her a look!
Old Mar 11, 2010 | 02:07 AM
sometimes the mounts on these cars hairline crack making it very hard to spot, so make sure u go over everything thoroughly
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
