Timing Chain Tensioner
car runs good, it wasnt my ticking problem tho(exhaust leak probably). Glad the new design is installed and off the list
i got it on my 4th attempt haha i was extremely happy it thread....i didnt even know it thread is just kept ratcheting it and i was like wait.... pulled the socket and it threads
i checked the usually spots it leaks and header was good and so was the dp 2 the header
it sounds like it could just be a normal sound the motor makes combined with the cat about to go or idk who cares the timing chain tensioner is installed WOOOO haha
Iirc its a 32mm socket, and torque it to spec. Dont remember what that is off the top of my head though.
Edit: Just found it, 55 ft lbs.
FYI - when rethreading the new tensioner, make sure you press on it with a CONSIDERABLE amount of force while simultaneously turning the bolthead. Otherwise the threads won't catch.
#37
I pulled my new one apart since I read I was supposed to set something. But didn't see anything. So I compressed it and re-installed the retaining clip.
Should it be good to go or is there something I have to do because I took the plunger out???
The way it sits the tensioner tip is spring loaded and takes a fair effort to press in still.
Im beyond paranoid to do this since this is my daily driver.
#43
Its no big deal when youve done it lol.
Im more concerned about **** popping apart into my motor, timing skipping and the vast amount of different opinions about how to do this.
Some say just screw it in.....some say lock it then release it once its screwed in. I cant afford a mistake with my daily.
