TPS on 2.2
Old Sep 6, 2008 | 03:39 PM
Balt36's Avatar
TPS on 2.2
can someone please tell me where my throttle positon sensor (TPS) on my 2005 chevy cobalt ls (2.2l) thak you!
Old Sep 6, 2008 | 03:41 PM
chris88z24's Avatar
It's a part of the TB if i'm not mistaken.
Old Sep 6, 2008 | 03:43 PM
originaladrian's Avatar
where can u tap the TPS signal wire or where is the actual TPS?
Old Sep 6, 2008 | 03:44 PM
chris88z24's Avatar
Old Sep 6, 2008 | 03:46 PM
FacelessKhaos's Avatar
the Sensor is behind the plastic top plate of your Throttle body. Don't open it up unless you know what you are doing. Unless you really wanna blow 400 dollars in the interest of curiosity. The parts that make the TPS sensor are VERY Delicate and can break easily.
Old Sep 6, 2008 | 06:56 PM
tru2nrtt777's Avatar
But there should be three wires coming out of it, one power/signal/ground. If you give me a couple days I can pull it up on alldata for you so you dont splice into the wrong one.
Old Sep 6, 2008 | 11:36 PM
yellowltcoupe22's Avatar
no need to look it up.. its the purple wire comin out of the TB.
Old Sep 7, 2008 | 11:35 AM
Correct sir. Purple is usually the color of a signal wire lol.
Old Sep 7, 2008 | 11:48 AM
lil_kano's Avatar
looks like some one is getting their nitrous kit installed...lol.
Old Sep 7, 2008 | 02:24 PM
Usually and always are two completely different things.
Old Sep 7, 2008 | 02:49 PM
mine is purple with a white line
Old Sep 7, 2008 | 05:57 PM
Hence the reasoning behind the word "usually"....being that the TPS Sensor signal wire is purple, and the signal wire from the 02 sensor is purple, (of course with different variations of said color such as white striped, red striped, etc) one can conclude that if you are looking for a signal wire from a sensor, it's probably purple.
Barkleyj605
Oct 24, 2015 12:07 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Tupp
Sep 29, 2015 11:07 PM
