transmission cooler
Old Aug 19, 2007 | 03:41 PM
freakta's Avatar
transmission cooler
im looking for a bit of information on a transmission cooler for the 2.2 auto. if there isnt any i can get a universal one from summit and post pictures and a writeup on here for everyone. does anyone know and have pictures of where the oil lines are on the tranny? or how many quarts of oil the tranny takes? thanks for the info
Old Aug 19, 2007 | 03:50 PM
Jackalope's Avatar
Well the trans is sealed, I'm not even sure where you could add fluid to it. That said a cooler depending on the size will hold about a 1/4 to a 1/2 qt. with the new lines too.
The lines on the Balt start off as aluminum and then switch to rubber. I'd say cut them off on the aluminum part, make a small flair and use 2 fuel injection style hose clamps to secure new hi-presure rubber line to the metal. It works just fine as long as you do it right.
Old Aug 19, 2007 | 04:57 PM
RedBaseBolt's Avatar
Our auto's already have a tranny cooler. pop your hood, look down the right hand side of the right fender by the radiator. there is a tranny cooler. a small one but its still there, you could replace that I would guess.
Old Aug 19, 2007 | 05:02 PM
Jackalope's Avatar
Thats actualy the tank of the radiator. He wants a seperate one to keep it cooler still.
Old Aug 19, 2007 | 05:10 PM
ted5986's Avatar
technically the one the auto cobalts have is a trans fluid warmer. its used to get the trans fluid up to operating temperature faster for smoother operation. as far as cooling goes, as long as you dont beat the **** out of your auto and you are not modded out of control. you shouldnt need to cool your trans fluid
Old Aug 19, 2007 | 05:17 PM
HunterKiller89's Avatar
its actually a trans cooler....it will use the warmth of the radiator to help warm the tranny fluid to X degrees, but then also cools it if it exceeds that temperature
you would want to get a tranny cooler if you climb a lot of steep hills, plan on increasing horsepower significantly, drive hard in hot temperatures, and a number of other reasons. Our auto trannies hold 11qts, but only 9 of it will drain. You'd need a machine to suck out the last 2 qts.
Old Aug 19, 2007 | 05:26 PM
Halfcent's Avatar
I'm old school
You don't have to cut anything. A typical cooler will need lines cut and made to length. Those lines can then replace the one that leads to the OEM cooler in the radiator.
The 4t45E takes about 13 quarts of fluid when it's completely dry.
Old Aug 19, 2007 | 05:59 PM
hah...halfcent,i would swear you told me 11 qts
Old Aug 19, 2007 | 06:16 PM
Halfcent's Avatar
I'm old school
http://media.gm.com/division/2005_pr...specs.html#mn4
10 quarts for an overhaul. 13 dry. Right out of the GM media.
Old Aug 19, 2007 | 06:25 PM
OrngBalt's Avatar
Well, if he wants to bring it to the track and starts doing alot of brake launches it would be a nice thing to have. Plus, a cooler transmission is a happy transmission. They arent that expensive and if it extends the life of our transmission... why not go for it.
Don't many of the kits come with all the necessary hoses and taps needed? Most of the ones I have seen do. There are quite a few guys talking about installing one, but to date, no one has come straight out and said they have. Make the how-to!
Old Aug 19, 2007 | 06:32 PM
Halfcent's Avatar
I'm old school
Most kits do have hoses for hooking it up. But they are generic in nature, and the hoses are often much longer then necessary. It is common for people to cut them to shorter lengths, and in doing so, attach different connection hardware.
Old Aug 19, 2007 | 06:53 PM
tonio5555's Avatar
There is a how to for a trans cooler on www.ecotecforum.com
Old Aug 19, 2007 | 11:44 PM
ORT's Avatar
ORT
Also, look up Celica Cobalt. He has one on his Balt. It is a 2.4 though, but I think that it will atleast point you into the right direction!
Old Aug 20, 2007 | 09:05 AM
freakta's Avatar
wow thanks for the input. i was gonna do it for longevity and with just a few mods it doesnt seem necessary. and the writeup on ecotechforums is great
Old Aug 20, 2007 | 12:43 PM
tonio5555's Avatar
I'm thinking about doing it as well. I mean all I'm doing to my car is bolt on's and maybe tuning if its comes out, so I won't need the tranny cooler. I just see it as a cool little project that is easy and I can only help, not hurt my car in the long run.
Old Sep 28, 2007 | 09:57 AM
originaladrian's Avatar
http://www.ecotecforum.com/forums/sh...mission+cooler
this is a how to with a cobalt
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
