Ut Oh is this bad
Old Mar 30, 2009 | 05:26 PM
boltedbalt's Avatar
Ut Oh is this bad
So if i really floor it, im an auto, between first and second, like right before it shifts to 2nd i hear like a slight squeal or whine...is this bad? any ideas thanks guys! and this only happens in first never any other gear!
Old Mar 30, 2009 | 05:28 PM
Sw4y1313's Avatar
your fine. my manual did that as well.
Old Mar 30, 2009 | 08:49 PM
YSUsteven's Avatar
Maybe it gear whine...
Old Mar 30, 2009 | 09:05 PM
tonio5555's Avatar
I get that too, I think its just the transmission mounts squeeling because they're not used to shifting so hard. I wouldn't worry about it. Then again I wouldn't be manually shifting it from L to I to D all the time, but thats another story.
Old Mar 30, 2009 | 11:04 PM
HunterKiller89's Avatar
i dont recall him saying he used L or I at all..
Old Mar 30, 2009 | 11:06 PM
Switt23's Avatar
My old cavalier did it, supposively due to it releasing line pressure between shifts. I had the BM shift plus and had it all the way up though.
Old Mar 31, 2009 | 09:21 AM
shawn672's Avatar
been doing this for 40k miles and my trans and mounts are fine
Old Mar 31, 2009 | 09:38 AM
PSHHH's Avatar
Is it like a grindin noise? cause usually when i shift from 3rd to 4th i get a grind sound like im missing the gear but im not it goes in gear just has a grind right before it slides in
Old Mar 31, 2009 | 07:32 PM
YSUsteven's Avatar
he has an auto tranny...
Old Apr 1, 2009 | 07:39 AM
shawn672's Avatar
and his car still shifts from 3rd to 4th..i dont see your point?
autos do slip/skip gears
Old Apr 1, 2009 | 07:41 AM
brickerenator's Avatar
Maybe you spun your tires?
Old Apr 1, 2009 | 11:04 AM
jbenso4's Avatar
does it in my car at the track
Old Apr 1, 2009 | 11:07 AM
PSHHH's Avatar
definatly not spun tires it really just sounds exactly like when u miss a gear and it grinds but im not missing the gear cuz it doesnt over rev or nothing just grinds for a short second then its done. usually only when im trying to slam through gears like if i shift to quick or hard.
Old Apr 1, 2009 | 11:09 AM
XxDHiLLxX's Avatar
it's your hidden supercharger.....they make this noise from time to time.
Old Apr 1, 2009 | 11:12 AM
JimzSS's Avatar
belt ensioner going south??
Old Apr 1, 2009 | 07:26 PM
YSUsteven's Avatar
An automatic is an entire differant animal from a manual, hence why
would not apply. While an auto might shift from gear to gear similar to a manual (the gear change) there is a huge differance in how the clutch vs. the clutch pacs operate, specifically the consistency of the auto and the lack there of for the manual. Also remember that the auto is shifting without letting the engine drop to the appropriate RPM, which you shuld do with a manual. If you don't you squeel the tires, where the auto slips the clutch pacs instead...
Easy answer, you can't compare apples to oranges, they are differant.
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
Trav3480
Sep 28, 2015 02:46 PM
Iceberg
Sep 28, 2015 01:31 PM
