ZZP LT Header: Code P0133, and P1133
Old Mar 7, 2011 | 12:05 PM
MadBrad's Avatar
After putting the Header on, I am throwing these two codes. Upstream O2 sensor. Not sure where to start. It could be many things at this point. Bad O2 sensor, location of where the O2 sensor is now, direction of O2 sensor now, or extension adapter supplied by ZZP is not giving signal from the ECU to the O2 sensor.
Not sure how the O2 sensor can read opposite flow like this.
Old Mar 7, 2011 | 12:17 PM
MadBrad's Avatar
Old Mar 7, 2011 | 12:54 PM
Mr.N00bLaR's Avatar
Maven is the only person I can think of that has this installed, he's also got a 2.2, might want to pm him.
Old Mar 7, 2011 | 01:52 PM
MadBrad's Avatar
Now maven and I have it on our 2.2's. I PM'd him. But he gets on once in a blue moon. In his LT Header thread he said he was throwing codes, but did not say which ones. It is very annoying, between 2K-2.5K rpms the car is extremely hesitant to move. Could be a leak. But it will also have a smooth idle, to almost want to die idle, and then back to smooth idle. Or our 2.2's don't like LT style headers.
Old Mar 7, 2011 | 02:04 PM
Mr.N00bLaR's Avatar
I didn't know he had issues other than sai. That sucks, my zzp lth in sitting in my room under my blower lol.
WWW.cobaltss.net/forums/5422866-post10.html
Did it always throw codes? Did you modify the extension properly to work with the 2.2 sensor?
Old Mar 7, 2011 | 08:40 PM
Maven's Avatar
the codes youre throwing are for the first O2 sensor, if you have installed after the cat in the position in your picture thats the problem, it belongs in the first position. Ive only ever thrown P013A and P013E, rarely and they are 2nd O2 sensor codes, but I am tuned now so they dont come on ant more either.
Old Mar 8, 2011 | 08:35 AM
MadBrad's Avatar
I can double check, but i am sure that the O2 sensor from the stock downpipe i put it back into the ZZP downpipe, and the other O2 sensor back into the merge collector at top.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
