ZZP Turbo....Stage 2...2.2...
Old Jun 8, 2010 | 10:38 AM
  #401
conerboner's Avatar
Vince said the throttle body might be bad but i don't see how it could be. It worked fine before I put the turbo on. I'm using the stock throttle body.
Old Jun 8, 2010 | 10:44 AM
  #402
elecblue06's Avatar
if you some how hit the plate or something it would **** it up
Old Jun 8, 2010 | 10:58 AM
  #403
conerboner's Avatar
I had tape over it the whole time so nothing would fall down there. I think it's either the throttle body or the ecm is fried.
Old Jun 8, 2010 | 02:52 PM
  #404
Spanky's Monkey's Avatar
i'm at a loss here. what cels are you showing now?
Old Jun 8, 2010 | 03:52 PM
  #405
conerboner's Avatar
P1516 and P2101. I have a new ecm waiting to get flashed to my vin # to see if that's the problem...
Old Jun 8, 2010 | 04:02 PM
  #406
i got a stock tb for ya if you wanna cover shipping? i have no use for it.
Old Jun 8, 2010 | 05:07 PM
  #407
conerboner's Avatar
I already tried a brand new throttle body and that didn't even work... Thanks for the offer though... The problem is the ecm isn't telling the throttle body what to do for some reason. I put a brand new pcm and the guy flashed the vin # and he can't even control the throttle body with the tech II...
Old Jun 9, 2010 | 06:20 AM
  #408
Cherry GT's Avatar
I don't get it, why so many issues ?
I always hear how "GOOD" Vince is.
Old Jun 9, 2010 | 09:28 AM
  #409
conerboner's Avatar
I am not saying Vince isn't "good", it's not his fault. Even he's stumped at this. It's just my luck that something would go wrong.
GOOD NEWS!!! I got it running. The whole time it was the wire we used to power the little pump for the liquid to air intercooler. We put a terminal into a slot in the fuse box in the engine bay and for some reason it was messing with the circuit and wouldn't allow the throttle body to go to the idle position. Now i'm trying to find a different place to power the pump.
Old Jun 9, 2010 | 06:43 PM
  #410
Cherry GT's Avatar
Great....... Glad its running.
Had a few issues today at the dyno,
but overall for the time being, I'm very happy.
Old Jun 9, 2010 | 06:47 PM
  #411
elecblue06's Avatar
dayum .. you need a better tune but that is sick 270 whp and wtrq and running in the 10s for AFR
Old Jun 9, 2010 | 06:49 PM
  #412
mmcgee123's Avatar
Suprised Vince didn't realize it we did the same thing when I did my turbo set up drove me nuts for 6-7 hrs until I started to really think about it
Old Jun 9, 2010 | 07:33 PM
  #413
06_ion2's Avatar
Nice numbers!
Old Jun 9, 2010 | 09:50 PM
  #414
Tundraboarder666's Avatar
Nice what turbo? how much boost?
Old Jun 10, 2010 | 07:26 AM
  #415
Cherry GT's Avatar
S256et, 10psi
Old Jun 10, 2010 | 11:29 AM
  #416
elecblue06's Avatar
get a retune and you'll hit like 290
Old Jun 10, 2010 | 08:38 PM
  #417
Originally Posted by Cherry GT
S256et, 10psi
Stock internals?
Old Jun 10, 2010 | 08:46 PM
  #418
Cherry GT's Avatar
Working on that.
Originally Posted by Tundraboarder666
Stock internals?
Yes sir, for now.
6psi for dd.
Old Jun 10, 2010 | 08:48 PM
  #419
Dayumm... Hope you dont break a rod man.
Old Jun 10, 2010 | 09:31 PM
  #420
conerboner's Avatar
I saw 8 psi the one time i did wot today. It feels like a brand new car.
Old Jun 10, 2010 | 09:36 PM
  #421
mkriebs's Avatar
Blow it and build it!
Old Jun 10, 2010 | 11:08 PM
  #422
06_ion2's Avatar
I think I need a bigger wastegate or I need a open dump, I see 21psi in 2nd and then in 3rd it goes from 17 to ~15. I dont have a boost controller, just a 15 psi spring. any ideas? It drives just fine though other than more boost in 2nd than id like.
Old Jun 10, 2010 | 11:12 PM
  #423
mkriebs's Avatar
Bigger wastegate would likely help. What are you running now?? Its obviously not opening/not flowing high enough.
Old Jun 10, 2010 | 11:22 PM
  #424
06_ion2's Avatar
its a tial 38mm v band. 3in downpipe and the wastegate dumps back into the exhaust.
Old Jun 10, 2010 | 11:40 PM
  #425
mkriebs's Avatar
Welllllllll that should be big enough. Thats what I was running on my 5557. You are running no boost controller? Right?? So thats out... Is it just a spike to 21 psi, or does it hold for a bit??
