2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Changing DRLs
Old Aug 8, 2011 | 10:21 PM
cobythecobalt's Avatar
Changing DRLs
Is it possible to change the DRL to be the turn signals only like in the Cobalts prior to 07? Or am I stuck with all or nothing?
Old Aug 15, 2011 | 12:43 PM
Anyone? Anyone at all?!
Old Aug 15, 2011 | 12:46 PM
J-Jeezy's Avatar
i think theres a running wire that comes from the drl fuse that leads to the headlight bulb. you could possible cut it and splice it into the running wires on the turn signal harness. just note that this will dramatically shorten the life of the bulb itself.
Old Aug 15, 2011 | 12:48 PM
TommyP's Avatar
AWD > FWD
Unfortunatley the DRLs are controlled by the BCM, so as far as I know there is no way to change it, unless it can be changed by a tech 2, but I've never looked into that.
Old Aug 15, 2011 | 01:04 PM
redcobalt07's Avatar
Rewire the headlight harness and switch the parking light and low beam wires. That is the only way unless you want to install some relays and pull the drl fuse.
Old Aug 15, 2011 | 03:33 PM
ok cool, thanks a lot.
Old Sep 2, 2011 | 03:12 PM
J-Jeezy's Avatar
That's what I ended up doing. I wired in a relay to my Car. Wired it to battery and ground. Then used a fuse tap from the wipers fuse and ran that wire to the signal pin on the relay. Then 2 wire from the lamp pin to the positive end on my running lights. Vwalah! DRLs
turbochargedss2012
Sep 20, 2023 12:17 PM
importkiller
Sep 30, 2015 07:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
roth
Sep 26, 2015 12:16 PM
