2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Engine swap?!?!?
Old Feb 3, 2012 | 12:27 PM
Mr.09cobalt's Avatar
Engine swap?!?!?
If u have a 2.2 cant u swap it out with a 2.4?
Old Feb 3, 2012 | 01:10 PM
redcobalt07's Avatar
Yes, but it's not that simple. All the wiring, sensors, and tuning will need to be modified.
Old Feb 3, 2012 | 11:45 PM
well i would wanna get te s/c 2.4 swap i wanna try to get the cumputer and all the stuff from the 2.4 and swap it over or just get a supercharger for a 2.2
Old Feb 3, 2012 | 11:58 PM
Maven's Avatar
Yes, its that simple. You just need a tune. LAP and LE5 are almost identical.
Old Feb 4, 2012 | 12:01 AM
nhanson's Avatar
I think its even possible to just swap blocks. But might be easier to do whole engine instead of dealing with timing stuff.
Old Feb 4, 2012 | 09:43 AM
so i could just keep the 2.2 and switch to a 2.4 block? will 2.2 parts like the 2.2 s/c still bolt up to that
Old Feb 4, 2012 | 09:49 AM
nhanson's Avatar
There is now 2.2 S/C. the supercharger is from the 2.0 on the LSJ
Old Feb 4, 2012 | 10:02 AM
would it be cheaper to find a used kit or jsut buy it new?
ZZPerformance - 2.2/2.4L Bolt on Supercharger Kit #ZZ-2224SCKT
Last edited by Mr.09cobalt; Feb 4, 2012 at 10:02 AM. Reason: Automerged Doublepost
Old Feb 4, 2012 | 10:04 AM
what are your thoughts on this too will it bolt up to my stock exhuast for now which is either a 1.5 or a 1.75" ZZPerformance - 2.5 inch Stainless Cobalt/Ion Downpipe #ZZ-E25DP i have a bad mab header ima put on it
Old Feb 4, 2012 | 01:19 PM
nhanson's Avatar
You can piece the kit for cheaper but if you don't know too much then get the kit
Old Feb 4, 2012 | 03:00 PM
cleanxfe's Avatar
id say go with the kit less head ache, seeing a fair amout of issues pieced together kits and make sure you get a good tune, and supporting mods is a no brainer ie. exhaust, clutch
Old Feb 4, 2012 | 03:05 PM
F_Imports_09tc's Avatar
AWD LSX swap
/thread
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
