2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
LAP and 89 octane
Old Aug 31, 2010 | 01:58 PM
RedBaseBolt's Avatar
LAP and 89 octane
Does anyone know if this motor would benefit from 89 octane with breathing mods?
IE: intake , shorty header, downpipe and 2.5" exhaust?
thanks
Old Aug 31, 2010 | 03:36 PM
umrdyldo's Avatar
No it won't benefit at all because the computer isn't tuned for it so it won't up the timing or anything past stock levels.
You really need a tune for 91 octane.
Old Sep 8, 2010 | 08:35 AM
strykr's Avatar
Not true, putting a full tank of higher octane gas in a vehicle once in a while will help clean up carbon deposits.. That will at the same time help your gas mileage. It won't help for power, because you need to tune the car for it though. And new cars that don't have tunes will automatically adjust itself to run the stock AFR so higher octane ONLY helps clean it when it's not tuned.
Old Oct 21, 2010 | 05:50 PM
Dimitri Manesis's Avatar
All of the fuel when they make it is 85 octane. They then put additives in the fuel to make it a higher octane. If you put a fuel with higher octane than require by the factory you get preignition which is real bad for your engine. Regular fuel is the cleanest fuel to burn. It leaves less carbon build up than midgrade or premium.
Dimitri
Old Oct 28, 2010 | 11:34 PM
nhanson's Avatar
Dimitri
you are ******* ass backword....
Tupp
Sep 30, 2015 08:18 PM
theamericanautos
Canadian North East
Sep 24, 2015 08:11 PM
twilson380
Sep 14, 2015 10:52 AM
Macgyver2484
Sep 2, 2015 05:44 PM
