2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
LE5 65mm TB on LAP
Old Mar 10, 2010 | 02:45 AM
cobalt523's Avatar
LE5 65mm TB on LAP
what parts from the 2.4 LE5 and ss will fit on my 09 2.2 LAP?
Old Mar 10, 2010 | 01:54 PM
xxxxsh4d0wxxxx's Avatar
I BELIEVE there is no reason to swap the intake manifold and TB on the 2009.
I THOUGHT that it was the same size as a 2.4, but it is a different style. Meaning you cannot swap.
Someone correct me if I am wrong.
Old Mar 10, 2010 | 02:21 PM
cobalt523's Avatar
thats what i heard but i was just checkin, ia there anything else off of the other stock cobalts that i can put on mine to increase performance, i also heard i can put a ss/sc header and down pipe on
Old Mar 10, 2010 | 03:09 PM
jbenso4's Avatar
you can but if u have sai, you would need to modify the header....check out gene gulleys build guide for example
as far as tb, not sure...it would fit but may require a eight piin connector....i know thats the way it is for lsj's
Old Mar 10, 2010 | 06:53 PM
cobalt523's Avatar
dumb question what is sai? lol i hear it all the time but i dont know
Old Mar 10, 2010 | 07:11 PM
jbenso4's Avatar
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/secondary-air-injection-late-production-2006-l61s-38488/
It is on most LAPs as well in that hread i will show u what to look for to see if u have it
Old Mar 10, 2010 | 08:10 PM
cobalt523's Avatar
i jsut checked and i dont see that port looking thing on my manifold, i heard only the xfe has the sai
Old Mar 10, 2010 | 08:42 PM
jbenso4's Avatar
it wouldnt be in manifold its on the intake. Its a small tube on the top of the airbox
Old Mar 11, 2010 | 10:07 AM
09blackonblack's Avatar
my xfe doesnt have sai. you can swap the manifolds and tb, but not worth it we have a 2.4 mani now just the 08 style. pre 07 will give you 1-2 hp at best. lsj manifold and dp will work. lnf turbo kit will work(i have the lsj header/dp on now) and the lnf turbo kit is going on soon. just a few small things to buy before i install.
Old Mar 11, 2010 | 10:55 AM
jbenso4's Avatar
my xfe has sai...so im jus sayin
Old Mar 11, 2010 | 01:49 PM
I have an XFE, no SAI.
Yes, it would give the LAP a little bit of power doing the manifold and TB swap, just not as nearly as much as it would for an 2008 and earlier, because ours are shittier.
Tupp
Sep 30, 2015 08:18 PM
theamericanautos
Canadian North East
Sep 24, 2015 08:11 PM
bobbob160
Sep 15, 2015 11:31 PM
socalsilverRL
Jan 24, 2007 01:59 PM
zinner
Sep 1, 2005 10:32 PM
