2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
LE5 gone SC!
Old 09-01-2013, 02:10 PM
  #101
Jacob4ta's Avatar
Originally Posted by Chaos_Six
Oh and for the alternator, did you leave it alone or space it out? If you used spacers how big were they, Im going to make my own. I assume half an inch to an inch?
No spacing at all for it. Unbolt and bolt back on. The idler pulley is around 2.85" I believe.
Old 09-01-2013, 03:28 PM
  #102
Chaos_Six's Avatar
Thanks man. I totally forgot about my idler setup. I don't have anything for it. I'm going to custom make a bracket and I guess order an idler. I'll probably get the oversized tensioner pulley from zzp and just mount it to whatever bracket i fabricate
Old 09-02-2013, 12:35 PM
  #103
Twoozofjuice's Avatar
bout 3/4 to an inch. Can't remember. But I'd really suggest getting the lsj stuff. It will be wayy easier to play with the belt. I had zzps idler setup before and I went through 2 tensioners on it. The belt was tight as hell and could barelyy get it on. Switched to lsj setup and the same belt is now wayy easier to get on and fits perfect instead of wayy too tight.
Old 09-02-2013, 12:48 PM
  #104
Chaos_Six's Avatar
I was thinking about getting the LSJ stuff, I'm going to grab it if I can ever find it used. The cheapest I found the actual tensioner was 170 bucks, but I forgot where that was. The LSJ Tensioner will bolt right on to the side of the LE5, correct? And yes, I'm going to space my alternator out an inch. Need to get some spacers and longer bolts. That's the easy part. :P
Old 09-02-2013, 02:25 PM
  #105
I picked up tensioner with bracket for $80. ebay from a junkyard
Old 09-02-2013, 05:12 PM
  #106
silver_stig's Avatar
I used the LSJ tensioner, bracket, idler, alternator, and stock belt. everything fits and works like factory.
I also figured out a trouble-free way to get the belt on and off. It involves a c-clamp.
Old 09-02-2013, 05:20 PM
  #107
Chaos_Six's Avatar
Please enlighten us as to how you do this :P
Old 09-02-2013, 09:22 PM
  #108
Ok. You'll need a C-clamp that spans at least 9 inches. you'll also need a flat piece if metal. I used a 5" long piece of 2" x 3/8" flat bar. you can use anything you have thats strong and flat.
Place the flat bar across from the engine mount to the tensioner. make sure its resting nice and flat on the belt.
Use the C-clamp to press down on the flat bar. the bottom of the c-clamp is supported by the lower part of the tensioner, where its bolted to your block. make sure its nice and vertical and begin clamping it down.
It goes down about 1-2 inches. The clamp will keep it there the whole time you work on your car. when youre done and you made sure the belt is sitting nicely, just release the clamp and youre done. The C-clamp I used was a 16" x 6". It was a bit large and tricky to get in there, but it worked good. I would recommend a 12" x 4" clamp.
Old 09-02-2013, 09:34 PM
  #109
Chaos_Six's Avatar
That's awesome! Definitely a different way to do it, that's for sure. I'm going to try this the first time I put my belt on. Thanks for this!
Old 09-02-2013, 10:58 PM
  #110
Yeah. It was one of the most frustrating things when I did my build. I think it took 3 of us half an hour just to put the belt on. Now it takes me 30 seconds and no effort.
Old 09-03-2013, 01:38 AM
  #111
Jacob4ta's Avatar
So from reading this, I should ditch my LE5 belt stuffs and go to LSJ idler, tensioner and alternator? Then everything will be happy with the blower?
Old 09-03-2013, 09:20 AM
  #112
Silver stig thats a different way to do it lol.
The way I do it is have the sc off and get a torx and out it in the middle of the tensioner pulley and use a 15mm wrench on thetop of it. Have someone push those 2 back and it makes the tensioner go down like 2 inches also. Then I just line up the supercharger and stick the bolts in and tighten them a little. Oh and put the belt on too lol. Then just release bolts after yyou've tightened a good amount. Takes an extra person but it is easy to do.
Old 09-03-2013, 01:29 PM
  #113
Chaos_Six's Avatar
That's what I'm going to do eventually
bobbob160
09-15-2015 11:31 PM
bigworm
05-15-2008 10:15 AM
fr33k
09-13-2007 02:37 PM
CSM Huber
08-22-2007 10:56 AM
WopOnTour
07-30-2007 11:03 AM
Quick Reply: LE5 gone SC!
