2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
LE5 gone SC!
Old Sep 1, 2013 | 02:10 PM
  #101
Jacob4ta's Avatar
Originally Posted by Chaos_Six
Oh and for the alternator, did you leave it alone or space it out? If you used spacers how big were they, Im going to make my own. I assume half an inch to an inch?
No spacing at all for it. Unbolt and bolt back on. The idler pulley is around 2.85" I believe.
Old Sep 1, 2013 | 03:28 PM
  #102
Chaos_Six's Avatar
Thanks man. I totally forgot about my idler setup. I don't have anything for it. I'm going to custom make a bracket and I guess order an idler. I'll probably get the oversized tensioner pulley from zzp and just mount it to whatever bracket i fabricate
Old Sep 2, 2013 | 12:35 PM
  #103
Twoozofjuice's Avatar
bout 3/4 to an inch. Can't remember. But I'd really suggest getting the lsj stuff. It will be wayy easier to play with the belt. I had zzps idler setup before and I went through 2 tensioners on it. The belt was tight as hell and could barelyy get it on. Switched to lsj setup and the same belt is now wayy easier to get on and fits perfect instead of wayy too tight.
Old Sep 2, 2013 | 12:48 PM
  #104
Chaos_Six's Avatar
I was thinking about getting the LSJ stuff, I'm going to grab it if I can ever find it used. The cheapest I found the actual tensioner was 170 bucks, but I forgot where that was. The LSJ Tensioner will bolt right on to the side of the LE5, correct? And yes, I'm going to space my alternator out an inch. Need to get some spacers and longer bolts. That's the easy part. :P
Old Sep 2, 2013 | 02:25 PM
  #105
I picked up tensioner with bracket for $80. ebay from a junkyard
Old Sep 2, 2013 | 05:12 PM
  #106
silver_stig's Avatar
I used the LSJ tensioner, bracket, idler, alternator, and stock belt. everything fits and works like factory.
I also figured out a trouble-free way to get the belt on and off. It involves a c-clamp.
Old Sep 2, 2013 | 05:20 PM
  #107
Chaos_Six's Avatar
Please enlighten us as to how you do this :P
Old Sep 2, 2013 | 09:22 PM
  #108
Ok. You'll need a C-clamp that spans at least 9 inches. you'll also need a flat piece if metal. I used a 5" long piece of 2" x 3/8" flat bar. you can use anything you have thats strong and flat.
Place the flat bar across from the engine mount to the tensioner. make sure its resting nice and flat on the belt.
Use the C-clamp to press down on the flat bar. the bottom of the c-clamp is supported by the lower part of the tensioner, where its bolted to your block. make sure its nice and vertical and begin clamping it down.
It goes down about 1-2 inches. The clamp will keep it there the whole time you work on your car. when youre done and you made sure the belt is sitting nicely, just release the clamp and youre done. The C-clamp I used was a 16" x 6". It was a bit large and tricky to get in there, but it worked good. I would recommend a 12" x 4" clamp.
Old Sep 2, 2013 | 09:34 PM
  #109
Chaos_Six's Avatar
That's awesome! Definitely a different way to do it, that's for sure. I'm going to try this the first time I put my belt on. Thanks for this!
Old Sep 2, 2013 | 10:58 PM
  #110
Yeah. It was one of the most frustrating things when I did my build. I think it took 3 of us half an hour just to put the belt on. Now it takes me 30 seconds and no effort.
Old Sep 3, 2013 | 01:38 AM
  #111
Jacob4ta's Avatar
So from reading this, I should ditch my LE5 belt stuffs and go to LSJ idler, tensioner and alternator? Then everything will be happy with the blower?
Old Sep 3, 2013 | 09:20 AM
  #112
Silver stig thats a different way to do it lol.
The way I do it is have the sc off and get a torx and out it in the middle of the tensioner pulley and use a 15mm wrench on thetop of it. Have someone push those 2 back and it makes the tensioner go down like 2 inches also. Then I just line up the supercharger and stick the bolts in and tighten them a little. Oh and put the belt on too lol. Then just release bolts after yyou've tightened a good amount. Takes an extra person but it is easy to do.
Old Sep 3, 2013 | 01:29 PM
  #113
Chaos_Six's Avatar
That's what I'm going to do eventually
bobbob160
Sep 15, 2015 11:31 PM
bigworm
May 15, 2008 10:15 AM
fr33k
Sep 13, 2007 02:37 PM
CSM Huber
Aug 22, 2007 10:56 AM
WopOnTour
Jul 30, 2007 11:03 AM
