2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Supercharged 2009 G5
Old Jul 27, 2017 | 03:15 PM
  #76
chevygirl2006's Avatar
Full cooling mods. My car has never heat soaked and you don't have to change the pump for e85. Stock is fine.
Old Jul 27, 2017 | 05:21 PM
  #77
Crav3's Avatar
Yea when my brother had the s3 heat exchanger it ran amazing, then when he broke it exiting his driveway the car didnt run the same. I do have a dual pass but i dont think it helps much without a bigger HE.
​​​​​​​Really? I had read about LSJ cobalts switching out the fuel pump for e85. Your making me want to switch to e85 lol. I just dont want my motor to blow up. Its not as strong as the 2.4
Old Jul 27, 2017 | 07:30 PM
  #78
No one swaps their fuel pumps lol unless they go tvs and bigger numbers. I was on the stock one 2 years. All my friends are too. I recommend getting the ottp h/e. The zzp is garbage. It bends so easy and cracks. I broke mine and bent it. Replaced it with ottp. So much stronger and made better. I've scrapped it a lot. Also cheaper.
  #79
Also, dual pass is the most important part. The stock h/e is actually enough.
Old Jul 27, 2017 | 09:23 PM
  #80
Crav3's Avatar
Wow i did not know that. Ill keep it in mind if i ever do go e85. I really wanted to get an lnf but then i lose one race and i want to build the g5 better and stronger.
​​​​​​​was thinking of getting the cx racing HE, it was like $130 i think. A friend had one and it was not bad.
​​​​​​​i did notice my iat temps go way down after the dual pass, even when going down a couple pulley sizes from stock. It is really good mod
Old Jul 27, 2017 | 09:48 PM
  #81
Lsj and turbo swap it
Old Jul 28, 2017 | 03:25 AM
  #82
Crav3's Avatar
I want to get an lsj and turbo it and put it in a miata. Also currently on the look out for a low priced miata to start an ecotec swap on it. Also know of a guy who took out his lnf and dropped in an LDK into it. So maybe ill pick that up if i find a miata.
Old Jul 28, 2017 | 09:00 AM
  #83
jdbaugh1's Avatar
I wonder if you would even be able to reap much benefit from E85 as the rods in 2.2's like to bend.
Ecotec swap Miata's are bad ass. There is one stripped down purpose built Ecotec Miata that I see at autocross events on slicks with a turbo ecotec and the thing flys around the courses. Honestly is right up there with the Exocets or other tube frame builds.
Old Jul 28, 2017 | 09:43 AM
  #84
I can't think of any stock motor 2.2s I know that are running e85
Old Jul 28, 2017 | 09:44 AM
  #85
But I don't think e85 and a sc kit is going to make enough power to bend a rod. You will till be under 300hp
Old Jul 28, 2017 | 10:13 AM
  #86
jdbaugh1's Avatar
I think our rods are safe to 250 and that is the max.
Old Jul 28, 2017 | 10:18 AM
  #87
That's what people say and it's not true. I know a few people that have more
Old Jul 28, 2017 | 10:33 AM
  #88
jdbaugh1's Avatar
I said safe, not impossible.
Old Jul 28, 2017 | 02:47 PM
  #89
The 250 number came from GM testing with a nitrous shot. Using a blower the power gain is different. You'll run cooler cylinder temps on e85 so that might help prolong things
Old Jul 28, 2017 | 02:52 PM
  #90
jdbaugh1's Avatar
When tuned correctly isn't a nitrous shot more healthy than boost from a supercharger because it is adding oxygen without additional heat and pressure?
Old Jul 28, 2017 | 03:11 PM
  #91
Crav3's Avatar
i remember back when i got my car around 2011 there was a guy running full cooling mods 2.9 pulley and e85 on a 2.2 LAP and only lasted a couple weeks before he bent a rod. That is why i dont want to do it just yet.
nitrous does not start to get harsh until after a 100 shot at a time. That is why they make stage kits. Its easy to take 2 small hits one after an other than one huge hit at once. I seen a 5.3 silverado take a 250 shot and blow up while another had a 2 stage kit spraying 150 shot then another 100 a bit after and survive many runs.
​​​​​​​yes i seen few ecotec miatas on youtbe and i gotta say im impressed. Even a stock 2.4 can run with turbo 1.6, 1.8 miatas. An lnf or lsj turbo in one would be crazy
Old Jul 28, 2017 | 03:14 PM
  #92
jdbaugh1's Avatar
The Miata I was talking about I think started with a 2.4 Ecotec and was very impressive them. Definitely enough power for autocross IMO. This year he is turbo'd and it went from impressive to nuts.
Old Jul 28, 2017 | 03:50 PM
  #93
Depends on how the nitrous and boost comes in. The supercharge is nice because it's more linear than a nitrous or turbo can be. They were hitting the poor little engine with a big shot at once
Old Jul 28, 2017 | 05:51 PM
  #94
Crav3's Avatar
​​​​​​​damn sounds like a car id like to see run. Is it a NA miata or NB? I always wanted a NA with the pop up headlights, but i always put it off and now their prices are going up. Im looking for a cheap NB right now but if a good priced NA comes out im taking it. They are fun little cars, and i cant imagine how fun they are with an ecotec
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Tupp
Sep 30, 2015 08:18 PM
z28addiction
Sep 28, 2015 12:03 AM
