08 LE5 downpipe
08 LE5 downpipe
08's have two cats in the downpipe. Anyone know the reason behind this?
I personally suspect it is to help meet more stringent exhaust emissions. I understand the two cats are smaller than the previous single cat, but same inside diameter, (although I haven't pulled mine out yet for a better look.) I also suspect that two smaller cats heat up faster than a single larger one. But of course the big question is, do two smaller cats adversely affect flow characteristics?
I am thinking about upgrading to a LSJ downpipe, but don't want to be bothered with the changed configuration throwing cels or whatever.
emissions. The first one us still pretty big second one is considerd a half cat
ur gonna throw cels just get a tune
Was installing the LSJ a worthwhile upgrade? I picked up a GMPP honed manifold for a good price. Combining it with the LSJ downpipe should work well, (in theory at least).
Thanks guys for the replies.
I don't really FEEL a difference to be honest. I never dynoed my car before so I can't give you before or after dyno numbers. There is a slight sound difference though that is most pleasant I can tell you that.
As for exhaust manifold I decided to keep it stock as I read gmpp manifold doesn't do much, and I don't want aftermarket cause either CEL or warranty. I am trying to find just a GMPP muffler tho to keep warranty for that if anyone knows where I can get just a GMPP touring muffler. Cause pretty much that's all our exhaust needs as we already have 2.50 piping. And as a surprising find, the gmpp cat-back exhaust is 2.25 piping! So technically GMPP cat-back is actually a downgrade! That's why I want just a muffler.
I didn't want to install headers either. The trick with headers, is that you get what you pay for. High end, long tube equal length tuned headers are not cheap, plus you need a corresponding downpipe. You want the headers tuned to the power band of the engine. I very much doubt many currently available on the market are.
The GMPP cat back is mandrel bent. The OEM stock isn't. The OEM stock also decreases to 2.25" over the axle. Even though the GMPP system is only 2.25", you can be sure it flows better than stock. The question is by how much? And is the benefit worth the cost?
BTW, for curiosity sake, how long have you had the LSJ installed for? (and why did you install it? Your questions suggest that you are not that experienced, but upgrading a downpipe is not something a novice normally attempts, unless instructed.)
Umm about a week ago. And I installed it cause it's less restriction and 60% bigger cat which means more performance! I don't really feel a difference though. But I'm guessing I probably would if I had the gmpp touring muffler as I'm sure a muffler is prob the most restrictive of an exhaust. Plus I don't want a real loud exhaust, and I like the sound of it. Can't I just take my car to midas or something and have them put a 2.5 pipe in and mandrel bend it then weld it? It sounds pretty simple. Doesn't sound like it should cost much either sounds like it wouldn't take more than 30 minutes of labor.
