2.4 to 2.0 Tranny Swap?
Old Jan 1, 2008 | 07:03 PM
Beck's Avatar
Having some major issues with my F23 transmission and the amount of torque i am putting down. What im curious is, how difficult would it be to swap a F35 onto the 2.4? If i can remember correctly the tranny itself will bolt up but the flywheel's will not swap due to the bolt patterns. I know axles would also have to be swapped etc.
basically im just curious if anyone has actually looked into this that could give me some info on what exactly needs to be swapped out here.
Old Jan 1, 2008 | 07:30 PM
REDFOCZ's Avatar
Talk to Fullthortle over on redline forums, I know he was trying to use his IRL tranny on his 2.4 the he swaped in.
Old Jan 1, 2008 | 11:38 PM
iLLmaTic3s's Avatar
wut happnin to the tranny man? very curious
Old Jan 1, 2008 | 11:41 PM
mike25's Avatar
also going to have to swith the clutch/shifter lines....it will def. be alot of work
Old Jan 1, 2008 | 11:54 PM
Witt's Avatar
Trust me on this, you don't want to do it. The 2.0 tranny sucks as far as gear ratios go. I'm in the process of deciding to either get rid of the car or do the Quaife 6 speed conversion for the longer first gear and shorter second.
Old Jan 2, 2008 | 12:12 AM
Beck's Avatar
***** breaking lol. they're only rated to 170 torque. im putting down around 270
Old Jan 4, 2008 | 10:05 PM
pjk91's Avatar
Can you have a tranny shop beef it up?
Old Jan 5, 2008 | 01:40 AM
Beck's Avatar
that's going to be the next thing i look into. I'll be pulling the tranny soon. have you installed your new clutch yet?
Old Jan 5, 2008 | 07:39 AM
pjk91's Avatar
Not yet, but it's definitely beginning to slip. I drive alot of highway, so I'm going to hopefully get another 10k out of it if I'm lucky.
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Sep 28, 2015 12:51 PM
