2.4 turbo build (for the haters! )
as soon as i get the chance i will replace the manifold and go to external wastegate being..then by the time the heat comes back around..step up the intercooler..and by then the turbo will probly be on its way out (i think ill get it to last with brandname wastegate and intercooling ..and lastly replace the turbo when funds are there..i honestly think the turbo will go long be4 the engine does..my statements on the engine blowing and not caring are just worst case scenario ..
honestly if i saved 3 ..ide sell and buy a new car..but the more i do to this thing the more im attached to it ..idk i honestly just have a good time messing with stuff and regardless to how much i spend on it in the long run ..it will be more rewarding to me knowing everything i did with it ya kno..
and to get feedback that isnt just "ur cars gunna blow up lol" would be nice
idc if its negative but y and how and what
Your still going to need some sort of custom charge pipes put together and that aint cheap from what ive seen! For the money your going to throw into a cheap Ebay kit why not just throw on an SS/SC M62? Can be done for pretty cheap and is pretty damn reliable IMHO. And would make more power alot safer than a junk Ebay kit that is poorly thrown together and will end up in not only toasting your motor, But the turbo too. WHich would lead to having to either return to stock or pay the $$$ and have it done right and doing it twice in the end! But hey it's your money... In for blown cobalt vids once put together!
inb4theiblewmyengine!!!!
Seriously though, it you plan on changing stuff out later on, why not just wait and get what you want. im not saying dont go ebay kit, because ive known people who have had good luck (not many at all though) But honestly i think you need to wait and read/research more and decide what the hell you want out of this car. If you dont want to spend 3g on it, dont go F/I. At that point your better off at getting a LSJ or LNF throwing the same amount your cheaping out on for a turbo kit and being better off reliabilty wise.
lol the charge piping is not going to be a problem ..pretty much put it together myself no welding of anything needed .. and i did consider the m62 for the longest time ..and i agreed its way more reliable ..but im simply not a fan of s/c and s/c is more expensive it ur looking to get any real power ..correct me in im wrong ..
and ok blowing my motor up ..how ? lol ill occupy the thought bcause agreed cheap products cheap response..but whats weak in an ebay set up ? ide say my weakest point ..is the wastegate ..not only is it ebay but its an internal wastegate and and is poorly set up (many stock turbos with internal wastegates r poorly set up )
i am def considering scrapping the internal wastegate ..dp and manifold ..other then that i cannot see how anything else may effect the engine
correction no scrapping of the dp needed bcuz im making it lol ..i thought of fabricating the manifold for a external wastegate but im worried about it cracking ..im not worried about the intercooler at all really .. or the piping ..and i think if the turbo is poorly maid..it will die way b4 my engine will
and ill probably rebuild it with the garrett rebuild kit
tmr i will post pictures of what i think i will be using and what not and we will get an opinion from there..none of u can tell me a storey of how u used som ebay turbo parts and how they failed miserably..and idk about u guys but im tired of hearing mixed reviews and i want to find out !
i cant say i havent seen it aswell .. i do agree that the internals on an ebay turbo are not quality ..but ive seen many success storeys from people rebuilding them with garrett rebuild kit being it will then have quality internally ..i think alot of the time its a seal blowing and theyll leak oil everywhere.. with the rebuild..and a name brand external wastegate ..i think it will hold up
Your an idiot if you think a ebay kit was made for your car. You can sit here and say that you will do all that is needed but you clearly have no freaking clue what your doing. you weak link is not only the ebay kit. scraping the DP/manifold and other thing's that crucial to a turbo build makes it very clear you have not done any research. if you think this has not been done before than you have no idea how the search button works. once again in for the blown turbo build just for the fun. what weak in an ebay kit is EVERY SINGLE PART. but go ahead and experiment like alot of people on this forum have.. Once you have blown your motor and turbo(which you admitted was possible) You will end up buying the same **** more than twice. Just do an S/C build and keep it safe as there are tons of how too's if you search. or continue on your path and waste $$$$$ it's up to you. if you were able to make a DP and charge piping then why hasnt it happend allready? CAUSE YOU HAVE NO CLUE WHAT YOUR DOING! Otherwise you would not be asking the questions you are! let alone trying to make junk **** work. And LOL at rebuilding what comes in an Ebay kit(two months down the road). Do it right the first time or dont bitch at doing it more than twice! cause that's what's going to happen!
oh and i dont think it was maid for my car..the only thing ebay can even claim fits is the exhaust manifold to head ..which as i said i dont know how sure i am about using ..but again i cant make an accusation without seeing the part….when i get them i will make the conclusion ..this thread is to try and see what is possible ..i can read from text books and search all day and get things right every time..but u learn the most when u experiment brother..jmo ..and ive done turbo set ups b4 ..but namebrand company was always who did the work and figuring out the kinks and percs in systems that im now trying to do
i know youre like oh i couldnt be so fortunate to find a kit like that blah blah blah. did you even try looking? ive seen 2-3 kits being sold here in the last month or 2 for less than 1k
heres one right now for $700!!! lmao!
https://www.cobaltss.net/forums/part...rembos-286960/
but yeah please post the video of the car blowing up
and i have to agree with chevygirl. if youre going to be cheap about modding your car then whats the point of even modifying it? its only going to give you more problems in the end and be more expensive than the more expensive part wouldve been
yes this is a complete kit for the lnf..this is no where near complete for what i would have to run ..only parts i could even use in that is the turbo and exhaust manifold ..mayb some of those lines im not sure how theyd run tho ..but for 700 ide be better buying a used garrett nd mani from zzp and i could get that for a lil less then 700..
few things just came in the mail ill take pictures tn when i have some more time ..the blades on the turbine seem to have scratches here in there..nothing drastic but theres no way for me to tell if its balanced ..w.e. scratched a blade could have bent something ..soo a rebuild will def be happening ..the manifold ..welds seem good but cuts and fitting are really bad ..and omg u sould see the downpipe that came with this thing ..i could only imagine how many people get this with no knowledge and bult right on blow up ..pics will be posted later!
